COMPLETE: Maintenance of ANL OC-12 AT 6:00 PM CDT
Bill Nickless
nickless at mcs.anl.gov
Thu Sep 2 19:00:06 CDT 1999
I am pleased to report that the problem with OC-12 signalling on Argonne's
OC-12 192.5.171.0/28 LIS has been corrected. Please consider the
maintenance window closed. All routing should be back to normal.
The problem had to do with a newly installed Gigabit Ethernet line card in
the chassis that did not have enough switch fabric bandwidth to support it.
Once I pulled the Gigabit Ethernet line card out, the problem went away.
IP multicast service should be restored. MSDP SAs are being received at
the ACCESS-DC site in Washington, DC.
Traceroutes from goshen.mcs.anl.gov to clipper-atm.lbl.gov are now correct:
goshen # traceroute clipper-atm.lbl.gov
traceroute to clipper-atm.lbl.gov (131.243.44.56): 1-30 hops, 38 byte packets
1 kiwi-oc12.anchor.anl.gov (192.5.171.1) 0.478 ms 0.531 ms 0.422 ms
2 esanl2-anl.es.net (198.124.254.165) 1.18 ms 1.46 ms 1.42 ms
3 esnetgsr-anlgsr.es.net (198.129.78.101) 44.2 ms 43.8 ms !H *
4 clipper-atm.lbl.gov (131.243.44.56) * 44.4 ms *
1 kiwi-oc12.anchor.anl.gov (192.5.171.1) 0.672 ms 0.253 ms 0.296 ms
2 esanl2-anl.es.net (198.124.254.165) 0.644 ms 0.780 ms 0.940 ms
3 esnetgsr-anlgsr.es.net (198.129.78.101) 43.8 ms 43.6 ms 43.6 ms
4 clipper-atm.lbl.gov (131.243.44.56) 43.8 ms * 43.9 ms
1 kiwi-oc12.anchor.anl.gov (192.5.171.1) 0.736 ms 0.436 ms 0.478 ms
2 esanl2-anl.es.net (198.124.254.165) 0.787 ms 0.703 ms 1.1 ms
3 esnetgsr-anlgsr.es.net (198.129.78.101) 43.8 ms 43.1 ms 43.9 ms
4 clipper-atm.lbl.gov (131.243.44.56) 44.3 ms * 44.3 ms
The first traceroute !H is consistent with the GSR at LBL not having a SVC
up. Note that it goes away by the second traceroute.
Bill Nickless http://www.mcs.anl.gov/people/nickless +1 630 252 7390
PGP:0E 0F 16 80 C5 B1 69 52 E1 44 1A A5 0E 1B 74 F7 nickless at mcs.anl.gov
