[alsa-user] Re: SBLive! noise (fwd)
Bob Olson
olson at mcs.anl.gov
Mon Dec 13 18:32:09 CST 1999
Hm. Too bad..
Bob Olson -*- olson at mcs.anl.gov -*- Argonne National Laboratory
---------- Forwarded message ----------
Date: Mon, 13 Dec 1999 14:15:42 -0800 (PST)
Reply-To: alsa-user at alsa-project.org
Subject: [alsa-user] Re: SBLive! noise
On Mon, 13 Dec 1999, Ian Wehrman wrote:
> second, i have a much more abstract problem... in short, the sound quality
> coming out of the front, analog, line out on the live card is not very clean.
> when the PCM control is turned up more than 60 or so, i can hear a lot of noise
> on the line. i'm using rather high quality cables to send the analog signal to
> the same receiver (and it sounded fine with my older opl3-sa3 based card). i
> suppose there are any number of things that could be causing this, but i was
> just wondering if this was a general problem with the emu10k1 drivers right now,
> or if i'm the only one having these problems... also, i get the same noise when
> i use creative's oss sound modules.
I think the general consensus is that the emu10k1 is a noisy chip. People
who used the windoze drivers had the same comments about noise, so it does
not look like it is specific to the drivers. One person commented that if
you turn down the analogue input levels (mic in, etc) it helps a bit.
-Dan
To unsubscribe from <alsa-user at alsa-project.org> mailing list send message
'unsubscribe' in the body of message to <alsa-user-request at alsa-project.org>.
BUG REPORTING SYSTEM: http://www.alsa-project.org/cgi-bin/bugs
