Tomorrow is C-Day minus 4
    Richard Coffey
    richardc at cs.utah.edu
    Wed Aug  4 17:59:44 CDT 1999
FILL OUT THIS INFO NOW
        http://www.mcs.anl.gov/fl/accessgrid/bobpage.htm
Who do I send mail to in order to change the info?
Cheers,
Richard
Mark Hereld wrote:
> Rick plans to use the AG tomorrow (Thursday 5 August) and Friday to practice delivery and tune up AG operations for the big day.  We need everynode that can to be on line so that we can bang on "interactive" use of the AG.
> Key ingredient is interaction.
> ANL/FL Workshop will source.  UNM will (if available) sink.  If UNM is unable, then we will practice with the ANL/FL Library acting as Proxy UNM.  This slot is important because we need to be prepared to protect the integrity of the broadcast with respect to the prime audience in case of network or other failure.
> And, finally, we will try to bring everybody up to spec on network time synchronization.  This is required for Voyager recordings.  We hope to record Rick's presentation and ALL of the AccessGrid streams for later stream-complex playback.
> These are pointers you should know:
> HOME BASE
>         http://www.mcs.anl.gov/fl/accessgrid/today.htm
> DIAGNOSTICS
>         http://www-unix.mcs.anl.gov/~olson/rtpmon/index.htm
>         http://www-unix.mcs.anl.gov/~olson/rtpmon-beacon/index.htm
> Cheers,
> Mark
Richard Coffey-Research Assistant    "Some people see things;
Scientific Computing and Imaging          and say, 'why?'
University of Utah (801)585-9834  I dream things that never were;
http://www.cs.utah.edu/~richardc        and say, 'why not?'"
                                       -George Bernard Shaw
