Bridge configuration changed
    Robert Olson
    olson at mcs.anl.gov
    Wed Aug  4 15:27:52 CDT 1999
Due to the large number of hosts on the bridges, I've split each of the
audio and video bridges. This means that depending on what host you are
coming from, you may have to connect to a different bridge. The current
configuration is at
http://www-unix.mcs.anl.gov/~olson/AG/bridge-summary.txt and included below.
Let me know if you have problems connecting.
--bob
Hosts for bridge putnam.mcs.anl.gov
Connect command is: vtc agaudio putnam.mcs.anl.gov agtest
         burble.bu.edu
         audio.unm.edu
         marge.ahpcc.unm.edu
         bohr.alliance.unm.edu
         audiomaui.mhpcc.edu
         ghafour.net.uky.edu
         audio.uky.edu
         accesso2.ncsa.uiuc.edu
         calder.ncsa.uiuc.edu
         niri.ncsa.uiuc.edu
         display-utah-ag.cs.utah.edu
         av1-utah-ag.cs.utah.edu
         tsunami.evl.uic.edu
Hosts for bridge fire.mcs.anl.gov
Connect command is: vtc agaudio fire.mcs.anl.gov agtest
         display.unm.edu
         audio.ahpcc.unm.edu
         display.ahpcc.unm.edu
         videomaui.mhpcc.edu
         goofy.ccs.uky.edu
         display.uky.edu
         mobile.ncsa.uiuc.edu
         stabile.ncsa.uiuc.edu
         av2-utah-ag.cs.utah.edu
         controller-utah-ag.cs.utah.edu
         em.evl.uic.edu
Hosts for bridge glamorgan.mcs.anl.gov
Connect command is: vtc ag glamorgan.mcs.anl.gov agtest
         burble.bu.edu
         video.unm.edu
         marge.ahpcc.unm.edu
         ghafour.net.uky.edu
         video.uky.edu
         niri.ncsa.uiuc.edu
         glacier.evl.uic.edu
         quark.evl.uic.edu
Hosts for bridge alaska.mcs.anl.gov
Connect command is: vtc ag alaska.mcs.anl.gov agtest
         display.unm.edu
         video.ahpcc.unm.edu
         videomaui.mhpcc.edu
         display.uky.edu
         picasso.ncsa.uiuc.edu
