[AG-DEV] Hard Coded anl.gov/140.221 references in 3.3-0r6835 source
Tim Salmon
tim at unsw.edu.au
Tue May 22 20:15:33 CDT 2012
hi salim,
for the time being it may be enough to just email it back and forth
between us: we're kind of 1/2 day out of time (i'm in sydney australia)
so it should be easy to keep any modifications in sync. as soon as the
new SVN site is available we can put it up there for more formal
collaboration. this should be manageable if one or two others wish to
be involved also.
regards,
tim
On 05/22/2012 09:28 PM, Salim Haniff wrote:
> Hi Tim,
> This was another situation I was wondering about. Currently, the
> script is broken down to 2 parts. The first handles renaming URLs in
> python2.x/site-packages/AccessGrid and the second renames URLs in
> ~/.AccessGrid3/Config. In fact one could comment out the function
> call to rename urls in python2.x/site-packages/AccessGrid or vice
> versa. Currently, there is some weird quark in the code that's not
> doing the renaming correctly and debugging it at the moment.
> Hopefully, it will be done by tomorrows end (Helsinki time). Can
> anyone recommend where I can upload the script?
> Earlier Jason had some requests:
> * The multicast beacon needs to be disabled by default, to
> ensure it works for windows 7 users.
> * Disable "submit bug" feature on Venue Client.
> I don't really know where the code portion part is to disable
> multicast for Windows 7 users, if someone could point that out it
> would be great. With the second request, I know where in the
> VenueClientUI code to comment out the "submit bug" menu option so it
> would not be active on the GUI. Would that be ok for now?
> Unfortunately, it looks like I cannot attend the meeting tonight.
> Best,
> Salim
> Quoting Tim Salmon <tim at unsw.edu.au>:
>> Dear Salim and others
>> that's a good location to identify and focus on. as far as
>> distributed solutions/scripts for switching things over we may wish
>> to consider manipulating user-space and non-userspace references with
>> separate scripts. firstly, for reasons of safety and also to cover
>> instances in which multiple accounts on the same machine are to be
>> reconfigured.
>> of course, the cleanest approach may be to erase ~/.AccessGrid3
>> folders and reinitialise with new configurations.
>> as soon as they are available, it may be preferable that systems are
>> "upgraded" with the installation of the rebuilt packages.
>> Given the distinct arrangement of files on Linux/Win/OSX it may be
>> simplest to build separate scripted reconfigurations for each platform.
>> Tim
>> On 05/22/2012 04:13 PM, Salim Haniff wrote:
>>> Hi,
>>> It seems on my AccessGrid installation there are files in
>>> ~/.AccessGrid3/Config that are called on by VenueClient..
>>> Config/myVenues.txt:4:Vhttps://v3.mcs.anl.gov:8000/Venues/000000ff74bbf9dc008c00dd00220007a23
>>> Config/profileCache/02bb21ff1b1f1ecac6535315f04255f1dc:10:home =
>>> https://vv3.mcs.anl.gov:8000/Venues/default
>>> Config/profile:10:home = https://vv3.mcs.anl.gov:8000/Venues/default
>>> Config/preferences:18:venueServerUrls =
>>> https://vv3.mcs.anl.gov:8000/VenueServer
>>> Config/trustedCACerts/45cc9e80.signing_policy:27: access_id_CA
>>> X509 '/O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid
>>> Developers CA'
>>> Config/trustedCACerts/45cc9e80.signing_policy:31: cond_subjects
>>> globus '"/O=Access Grid/OU=agdev-ca.mcs.anl.gov/*"'
>>> Config/certRepo/certificates/809ecc45460c1482e61e26bdfbf9e18c/4665b7fa3dc5e3e1870d794559764226/user_files/signing_policy:27:
>>> access_id_CA X509 '/O=Access
>>> Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid Developers CA'
>>> Config/certRepo/certificates/809ecc45460c1482e61e26bdfbf9e18c/4665b7fa3dc5e3e1870d794559764226/user_files/signing_policy:31:
>>> cond_subjects globus '"/O=Access
>>> Do these need to be changed as well? I'm currently in the process
>>> of writing the script in Python that changes instances of
>>> mcs.anl.gov to accessgrid.org. I was wondering though about the
>>> certificates that contain the OU=...mcs.anl.gov though. In
>>> addition, there are a lot of email addresses going back to anl.gov
>>> should I just overwrite that with accessgrid.org for now?
>>> Best,
>>> Salim
