[AG-DEV] Continual of AG services
Jason Bell
j.bell at cqu.edu.au
Fri Mar 16 00:36:14 CDT 2012
Gabriel and All
Though I am encouraged to see enthusiasm with regards to getting services migrated, I would personally like to see some robust discussions on platforms, systems and services, before any migration takes place.
For example, in regards to "source forge", a few people have indicated that they don't personally like it, due to the advertising and misleading redirection when downloading packages.
Now, I am not sure if this is a "real" issue with regards to maintaining a repository, but I think it warrants further discussion.
Therefore, I encourage others to contribute and propose alternatives (if any) on the variety of services that have been listed.
Now is the time to "have your say"!
Many thanks,
Jason.
-----Original Message-----
From: ag-dev-bounces at lists.mcs.anl.gov [mailto:ag-dev-bounces at lists.mcs.anl.gov] On Behalf Of Gabriel Noronha
Sent: Friday, 16 March 2012 07:42 AM
To: ag-dev at mcs.anl.gov
Subject: Re: [AG-DEV] Continual of AG services
Hi everyone
It some respects it would look good if we got started on migrating some of the services of AG. mainly if the project looks dead it's harder to get things happening.
I can't do much development but i can set up a source forge account. and do svn task
so ideally we can import the full svn repository complete with comments and old revisions
if someone with shell access to the current svn repo could they do the following :
Discuss your proposed changes with your Project Team.
Use svnadmin dump /PATH/TO/REPO > svndump to create a dump file named "svndump".
It is a good idea to compress the resulting dump file, to save space. We support zip, bzip2, and gzip compression (do not tar it).
instructions from source forge. http://sourceforge.net/apps/trac/sourceforge/wiki/SVN%20adminrepo#ImportingfromotherreposincludingotherSCMs
sourceforge also supports mailing lists mailman same as what anl use not sure if they support a history import of that through will investigate.
Gabriel
Gabriel Noronha
Access Grid Support Officer
University of Newcastle
NSW, Australia
