[AG-DEV] resurrecting AGVCRtoMPEG2
Gabriel Noronha
Gabriel.Noronha at newcastle.edu.au
Thu Jun 16 06:49:40 CDT 2011
Hi all
AGVCRtoMPEG2 converts AGVCR recordings to something more useful for playback eg mpeg2 and mp3.
so far the project was abandon 5 years ago https://trac.ci.uchicago.edu/if-media/browser/AGVCRToMPEG2
the code for 5 years ago successfully can extract h261 and audio and produce mpeg2 and mp3's.
I tracked the name of the orginal dev Yifan Lu but it seems he's to have moved on.
In my efforts to understand it a bit better I've run the source through doxygen to get call graphs and a understanding of flow.
http://noronha.id.au/AGVCRToMPEG2/files.html
I've noticed he's copied code from VPC project and VPMedia but then deleted stuff. Is their any active documentation for those projects ? and is any active devs out their able to tell me if the new code will just copy and paste in ?
currently waiting on uchicargo to give me svn access to upload any changes their is already a patch to allow it to compile with newer gcc and some new ubuntu install instructions. 11.04
plans just so you know: (in order sorta)
full codec support h264 h261as and mpeg4
different arrangements for videos 1 large rest small etc..
update to use new ffmpeg functions so not using superseeded functions.
64 bit support
GPU accelerated (dreaming)
new UI (maybe)
yours
Gabriel
Gabriel Noronha
Access Grid Support Officer
University of Newcastle
