[AG-DEV] Unicast bridge enable bug for windows!
Nikkos Svoboda
nsvoboda at math.lsu.edu
Mon Aug 22 17:29:06 CDT 2011
I've already submitted a bug report and solution for this awhile
back. Look at the following page for the actual fix:
[ http://bugzilla.mcs.anl.gov/accessgrid/show_bug.cgi?id=1941 ]
-Nikkos Svoboda
LSU Department of Mathematics
On 8/22/2011 8:48 AM, William Alberto Romero Ramirez wrote:
> We've got the same problem!
> At COLIVRI (Co-Laboratory of Interaction, Visualisation, Robotics, and Automation), we have a linux cluster +multicast. That's why we don't utilise a bridge.
> We utilise AG 3.1 (on Windows XP) for our nodes outside of the university campus.
> Cheers,
> ______________________________________________
> William A. Romero R.<http://www.waromero.com>
> Research Engineer
> IMAGINE - Visual Computing research group
> <http://imagine.uniandes.edu.co>
> Universidad de los Andes
> <http://www.uniandes.edu.co>
> Bogotá D.C., Colombia
> Tel.:+ 57 1 339 49 49 Ext.: 3462
> ----- Mensaje original -----
> De: Jason Bell<j.bell at cqu.edu.au>
> Fecha: Lunes, 22 de Agosto de 2011, 2:32 am
> Asunto: Re: [AG-DEV] Unicast bridge enable bug for windows!
> A: Thomas D Uram<turam at mcs.anl.gov>
> CC: ag-dev<ag-dev at mcs.anl.gov>
> Tom
> When you click on the enable button, it disappears and doesn’t enable it.
> Cheers,
> Jason.
> From: Thomas D Uram [mailto:turam at mcs.anl.gov]
>> Sent: Monday, 22 August 2011 5:05 PM
>> To: Jason Bell
>> Cc: ag-dev
>> Subject: Re: [AG-DEV] Unicast bridge enable bug for windows!
> /how/ does it not work?
>> Am Aug 22, 2011 um 1:37 AM schrieb Jason Bell<j.bell at cqu.edu.au>:
> Hi Guys
> I have stumbled across a bug for windows users of the Access Grid (3.2) software – which has been confirmed on Windows XP and 7.
> Windows users are unable to enable a Unicast Bridge that is currently listed as "disabled". Normally you would (this works for Mac and Linux) open up Tools -> Preferences -> Bridging, select a bridge, right click on the “disable” text and select enable. This doesn't work on either Windows XP or Windows 7.
> Bug has been logged via bugzilla (Bug 1975).
> There is a work around, which is to edit the following text file manually:
> Windows XP: C:\Documents and Settings\[username]\Application Data\AccessGrid3\Caches
> Windows 7: C:\Users\[username]\AppData\Roaming\AccessGrid3\Caches
> and manually edit the bridges file (using wordpad is fine).
> Simply locate the desired bridges, based upon "name" and change the status to "Enabled". Save the file and these bridges should then be listed. An example is listed below:
> [82664eb260b41608a24968d14787fc3a]
> status = Enabled
> name = APAG
> portMax = 52000
> serverType = QuickBridge
> rank = 0.0320000648499
> host = vv3.ap-accessgrid.org
> portMin = 50000
> userRank = 3.0
> port = 20000
> description =
> I have documented this work around at http://www.accessgrid.org/node/2566
> Hope this helps others.
> Regards,
> Jason.
> Jason Bell, B.I.T. (Honours)
> Video Collaboration Champion
> Queensland Cyber Infrastructure Foundation
> http://www.qcif.edu.au/
> ARCS eResearch Collaborative Services
> http://www.arcs.org.au/
> Senior Research Technologies Officer
> Information Technology Directorate
> CQ University Australia
> http://www.cqu.edu.au/
> E-mail : j.bell at cqu.edu.au
> j.bell at qcif.edu.au
> jason.bell at arcs.org.au
> Work : +61 7 4930 9229
> Mobile : 0409 630897
> Postal : Building 19, Room 1.55
> Central Queensland University
> Bruce Highway
> Rockhampton, Queensland, Australia, 4702
> Patience is a virtue.
> But if I wanted Patience,
> I would have become a Doctor.
