[AG-DEV] Unicast bridge enable bug for windows!
William Alberto Romero Ramirez
wil-rome at uniandes.edu.co
Mon Aug 22 08:48:54 CDT 2011
We've got the same problem!
At COLIVRI (Co-Laboratory of Interaction, Visualisation, Robotics, and Automation), we have a linux cluster +multicast. That's why we don't utilise a bridge.
We utilise AG 3.1 (on Windows XP) for our nodes outside of the university campus.
Cheers,
______________________________________________
William A. Romero R. <http://www.waromero.com>
Research Engineer
IMAGINE - Visual Computing research group
<http://imagine.uniandes.edu.co>
Universidad de los Andes
<http://www.uniandes.edu.co>
Bogotá D.C., Colombia
Tel.:+ 57 1 339 49 49 Ext.: 3462
----- Mensaje original -----
De: Jason Bell <j.bell at cqu.edu.au>
Fecha: Lunes, 22 de Agosto de 2011, 2:32 am
Asunto: Re: [AG-DEV] Unicast bridge enable bug for windows!
A: Thomas D Uram <turam at mcs.anl.gov>
CC: ag-dev <ag-dev at mcs.anl.gov>
Tom
When you click on the enable button, it disappears and doesn’t enable it.
Cheers,
Jason.
> Sent: Monday, 22 August 2011 5:05 PM
> To: Jason Bell
> Cc: ag-dev
> Subject: Re: [AG-DEV] Unicast bridge enable bug for windows!
/how/ does it not work?
> Am Aug 22, 2011 um 1:37 AM schrieb Jason Bell <j.bell at cqu.edu.au>:
Hi Guys
I have stumbled across a bug for windows users of the Access Grid (3.2) software – which has been confirmed on Windows XP and 7.
Windows users are unable to enable a Unicast Bridge that is currently listed as "disabled". Normally you would (this works for Mac and Linux) open up Tools -> Preferences -> Bridging, select a bridge, right click on the “disable” text and select enable. This doesn't work on either Windows XP or Windows 7.
Bug has been logged via bugzilla (Bug 1975).
There is a work around, which is to edit the following text file manually:
Windows XP: C:\Documents and Settings\[username]\Application Data\AccessGrid3\Caches
Windows 7: C:\Users\[username]\AppData\Roaming\AccessGrid3\Caches
and manually edit the bridges file (using wordpad is fine).
Simply locate the desired bridges, based upon "name" and change the status to "Enabled". Save the file and these bridges should then be listed. An example is listed below:
[82664eb260b41608a24968d14787fc3a]
status = Enabled
name = APAG
portMax = 52000
serverType = QuickBridge
rank = 0.0320000648499
host = vv3.ap-accessgrid.org
portMin = 50000
userRank = 3.0
port = 20000
description =
I have documented this work around at http://www.accessgrid.org/node/2566
Hope this helps others.
Jason.
Jason Bell, B.I.T. (Honours)
Video Collaboration Champion
Queensland Cyber Infrastructure Foundation
http://www.qcif.edu.au/
ARCS eResearch Collaborative Services
http://www.arcs.org.au/
Senior Research Technologies Officer
Information Technology Directorate
CQ University Australia
http://www.cqu.edu.au/
E-mail : j.bell at cqu.edu.au
j.bell at qcif.edu.au
jason.bell at arcs.org.au
Work : +61 7 4930 9229
Mobile : 0409 630897
Postal : Building 19, Room 1.55
Central Queensland University
Bruce Highway
Rockhampton, Queensland, Australia, 4702
Patience is a virtue.
But if I wanted Patience,
I would have become a Doctor.
