[AG-DEV] Cert issues on Fedora 12
Jason Bell
j.bell at cqu.edu.au
Wed Feb 24 22:48:05 CST 2010
G'day All
Just wondering if any has installed Fedora 12 and the Access Grid software recently.
I have tried to install the AG software at home and got some error messages which appears to relate to the certificate.
Just wondering if anyone has seen this.
Jason.
PS, this is the error message I get:
/usr/lib/python2.6/site-packages/ZSI/resolvers.py:7: DeprecationWarning: the multifile module has been deprecated since Python 2.5
import multifile, mimetools, urllib
Starting Service URI: http://127.0.0.1:49475/Services/AudioService.7f0000011e0e1d7ab29946690480bba7df
02/14/2010 03:36:05 PM 140196559439632 ServiceManager AGServiceManager.py:234 INFO Service registered: token,url = 7f0000011e001d7ab29922d3397a8af89e,http://127.0.0.1:49475/Services/AudioService.7f0000011e0e1d7ab29946690480bba7df
02/14/2010 03:36:05 PM 140196569929488 ServiceManager AGServiceManager.py:422 INFO Service registered: http://127.0.0.1:49475/Services/AudioService.7f0000011e0e1d7ab29946690480bba7df 7f0000011e001d7ab29922d3397a8af89e
02/14/2010 03:36:05 PM 140196569929488 ServiceManager AGServiceManager.py:103 INFO AGServiceManager.AddService
02/14/2010 03:36:05 PM 140196569929488 ServiceManager AGServiceManager.py:343 INFO Installed service version: 3.1, package version: 3.1
02/14/2010 03:36:05 PM 140196569929488 ServiceManager AGServiceManager.py:378 DEBUG Executing service VideoConsumerService
02/14/2010 03:36:05 PM 140196569929488 ServiceManager AGServiceManager.py:410 INFO Running Service; options: ['/home/ace/.AccessGrid3/local_services/VideoConsumerService/VideoConsumerService.py', '--port', 64412, '--serviceManagerUri', 'http://127.0.0.1:11000/ServiceManager', '--token', '7f0000011e001d7ab299577eaf61c6b03a']
/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/ClientProfile.py:22: DeprecationWarning: the md5 module is deprecated; use hashlib instead
import md5
/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/Security/ProxyGen.py:19: DeprecationWarning: The popen2 module is deprecated. Use the subprocess module.
import popen2
Starting Service URI: http://127.0.0.1:64412/Services/VideoConsumerService.7f0000011e141d7ab2997056eb7cf7a3d5
02/14/2010 03:36:06 PM 140196559439632 ServiceManager AGServiceManager.py:234 INFO Service registered: token,url = 7f0000011e001d7ab299577eaf61c6b03a,http://127.0.0.1:64412/Services/VideoConsumerService.7f0000011e141d7ab2997056eb7cf7a3d5
02/14/2010 03:36:06 PM 140196569929488 ServiceManager AGServiceManager.py:422 INFO Service registered: http://127.0.0.1:64412/Services/VideoConsumerService.7f0000011e141d7ab2997056eb7cf7a3d5 7f0000011e001d7ab299577eaf61c6b03a
02/14/2010 03:36:06 PM 140196948985600 VenueClient VenueClient.py:365 DEBUG get bridges from registry
02/14/2010 03:36:06 PM 140196948985600 VenueClient VenueClient.py:371 DEBUG Trying bridge registry: http://www.accessgrid.org/registry/peers.txt
02/14/2010 03:36:06 PM 140196948985600 VenueClient Preferences.py:188 DEBUG Preferences.LoadPreferences: open file
02/14/2010 03:36:09 PM 140196948985600 VenueClient VenueClient.py:371 DEBUG Trying bridge registry: http://www.ap-accessgrid.org/registry/peers.txt
02/14/2010 03:36:09 PM 140196948985600 VenueClient Preferences.py:188 DEBUG Preferences.LoadPreferences: open file
02/14/2010 03:36:09 PM 140196948985600 VenueClient VenueClient.py:397 DEBUG connect to bridge
02/14/2010 03:36:09 PM 140196948985600 VenueClient VenueClient.py:401 DEBUG exiting loadbridges
02/14/2010 03:36:09 PM 140196948985600 NodeService AGNodeService.py:289 INFO NodeService.SetServiceEnabledByMediaType
02/14/2010 03:36:09 PM 140196948985600 NodeService AGNodeService.py:258 INFO NodeService.GetServices
02/14/2010 03:36:09 PM 140196559439632 ServiceManager AGServiceManager.py:220 INFO AGServiceManager.GetServices
02/14/2010 03:36:09 PM 140196948985600 NodeService AGNodeService.py:275 INFO NodeService.SetServiceEnabled
02/14/2010 03:36:09 PM 140196948985600 NodeService AGNodeService.py:701 INFO NodeService.__SendStreamsToService
02/14/2010 03:36:09 PM 140196948985600 NodeService AGNodeService.py:705 DEBUG service capabilities: [consumer, audio, 7f0000011e0e1d7ab2993d1349a0aab1bc, L16, 16000, 1, None, None, consumer, audio, 7f0000011e0e1d7ab2993d1349a0aab1bc, L16, 8000, 1, None, None, consumer, audio, 7f0000011e0e1d7ab2993d1349a0aab1bc, L8, 16000, 1, None, None, consumer, audio, 7f0000011e0e1d7ab2993d1349a0aab1bc, L8, 8000, 1, None, None, consumer, audio, 7f0000011e0e1d7ab2993d1349a0aab1bc, PCMU, 16000, 1, None, None, consumer, audio, 7f0000011e0e1d7ab2993d1349a0aab1bc, PCMU, 8000, 1, None, None, consumer, audio, 7f0000011e0e1d7ab2993d1349a0aab1bc, GSM, 16000, 1, None, None, consumer, audio, 7f0000011e0e1d7ab2993d1349a0aab1bc, GSM, 8000, 1, None, None, producer, audio, 7f0000011e0e1d7ab2993d1349a0aab1bc, L16, 16000, 1, None, None]
02/14/2010 03:36:10 PM 140196948985600 NodeService AGNodeService.py:258 INFO NodeService.GetServices
02/14/2010 03:36:10 PM 140196559439632 ServiceManager AGServiceManager.py:220 INFO AGServiceManager.GetServices
02/14/2010 03:36:10 PM 140196948985600 NodeService AGNodeService.py:640 INFO NodeService.GetConfigurations
02/14/2010 03:36:10 PM 140196948985600 CertificateManager CertificateManager.py:212 DEBUG Opened repository /home/ace/.AccessGrid3/Config/certRepo
02/14/2010 03:36:10 PM 140196948985600 Toolkit Toolkit.py:472 INFO Initialized certificate manager.
02/14/2010 03:36:10 PM 140196948985600 VenueClient VenueClientUI.py:536 ERROR VenueClientFrame.__SetMenubar: Cannot retrieve certificate mgr user interface, continuing
Traceback (most recent call last):
File "/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/VenueClientUI.py", line 533, in __SetMenubar
mgr = app.GetCertificateManager()
File "/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/Toolkit.py", line 473, in GetCertificateManager
self._certificateManager.InitEnvironment()
File "/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/Security/CertificateManager.py", line 564, in InitEnvironment
self._InitializeCADir()
File "/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/Security/CertificateManager.py", line 645, in _InitializeCADir
for c in self.GetCACerts():
File "/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/Security/CertificateManager.py", line 768, in GetCACerts
caCerts = self.certRepo.FindCertificatesWithMetadata(mdkey, mdval)
File "/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/Security/CertificateRepository.py", line 1201, in FindCertificatesWithMetadata
return list(self.FindCertificates(lambda c: c.GetMetadata(mdkey) == mdvalue))
File "/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/Security/CertificateRepository.py", line 1191, in FindCertificates
if pred(cert):
File "/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/Security/CertificateRepository.py", line 1201, in <lambda>
File "/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/Security/CertificateRepository.py", line 1297, in GetMetadata
return self.cert.GetMetadata(k)
File "/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/Security/CertificateRepository.py", line 1590, in GetMetadata
hashkey = self._GetMetadataKey(key)
File "/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/Security/CertificateRepository.py", line 1579, in _GetMetadataKey
self.GetIssuerSerialHash(),
File "/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/Security/CertificateRepository.py", line 1504, in GetIssuerSerialHash
serial = struct.pack("l", self.cert.get_serial_number())
error: long too large to convert to int
File "/usr/bin/VenueClient", line 173, in <module>
main()
File "/usr/bin/VenueClient", line 150, in main
vcui = VenueClientUI(vc, vcc, app)
File "/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/VenueClientUI.py", line 237, in __init__
self.__BuildUI(app)
File "/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/VenueClientUI.py", line 980, in __BuildUI
self.__SetMenubar(app)
File "/usr/lib/python2.6/site-packages/AccessGrid3/AccessGrid/VenueClientUI.py", line 538, in __SetMenubar
self.cmui = CertificateManagerWXGUI.CertificateManagerWXGUI(mgr)
UnboundLocalError: local variable 'mgr' referenced before assignment
Jason Bell, B.I.T. (Honours)
Research Systems Support Officer
Information Technology Division
CQ University Australia
Australian Research Collaboration Service
http://www.arcs.org.au/
E-mail : j.bell at cqu.edu.au
jason.bell at arcs.org.au
Work : +61 7 4930 9229
Mobile : 0409 630897
Postal : Building 19
Central Queensland University
Bruce Highway
Rockhampton, Queensland, Australia, 4702
Patience is a virtue.
But if I wanted Patience,
I would have become a Doctor.
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20100225/83fb2d6d/attachment.htm>
