[AG-DEV] Identity certificates
Thomas D. Uram
turam at mcs.anl.gov
Fri Mar 14 01:15:04 CDT 2008
Luis:
The video capture machine has, in the past, often run Linux, which is
why you got that impression from looking at older documentation.
In AG3, vic can use USB cameras, firewire cameras, and dedicated capture
cards with either a VFW (older) or WDM/DirectShow (newer) driver. You
should be having success in either of these cases. If you're not, we
need to look into the cause a little deeper. Provide more details of
the problems you ran into, and your configuration, and I/we can help.
There are add-on services for transmitting/receiving video using VLC
(http://netmedia.gist.ac.kr/agdv/download.html). These have so far only
been made available on Windows, but it would be trivial to make them
also work under Linux (with VLC; DVTS would be more difficult).
Tom
On 3/13/08 10:07 AM, Luis Galárraga wrote:
> Thanks a lot for your help Tom. I have two additional questions, but
> they related to audio and video transmision. As I mentioned, our
> objective are single node users which should have just a webcam and a
> microphone to participate in a webinar. People here in ESPOL
> (colleagues but not members of this project), have successfully tested
> AG in node configuration, but when we tried with a single computer, we
> could not transmit video. Worried about this fact, I read all
> documentation about VIC and understood that it requires a video
> capture card (our colleagues had one) for transmitting video. Reviews
> and documentation about node configurations indicate that the video
> capture computer should be a Linux machine with a video capture card
> and that only in Windows it is possible do it with a usb webcam or a
> firewire camera (no video card needed). Our tests were in both
> platforms without success. Do Linux users need a frame grabber for
> transmit video? Is it possible to use another tool like VLC for
> transmitting video? We had successful results transmitting multicast
> video streams from a webcam using VLC in Ubuntu Linux and Windows XP.
> In addition, we found a way of redirecting raw video to another
> application instead of showing it with VLC.
> Thanks again.
> Luis,
> 2008/3/13, Thomas D. Uram <turam at mcs.anl.gov <mailto:turam at mcs.anl.gov>>:
> Hi Luis:
> There are a few things you need to know in this regard:
> - By default, AG3 venues do not require that clients have a
> certificate
> to enter. Venues can be optionally configured to require a
> certificate,
> in which case the user must present a certificate that satisfies the
> access controls on the venue.
> - You can run your own CA and issue your own certificates. In that
> case, you'll need to make sure your clients have both your CA
> certificate and their personal certificate.
> Otherwise, this is general PKI. If you have other questions, don't
> hesitate to ask.
> Tom
> On 3/6/08 3:41 PM, Luis Galárraga wrote:
> > Greetings:
> > I am part of project for developing a webinar infraestructure
> based on
> > Access Grid. After a long discussion in which suggestions in this
> > mailing list were strongly considered, we have decided to
> implement a
> > simple client for venues (in servers 3.x) using Java Web Start Apps.
> > As you can see, there are many things to do, and developers have
> > started by making tests with the soap interfaces in the our AG
> server,
> > however they are not clear about the concepts behind the
> > authentication process. We know AG uses digital certificates for
> > everything: users and services and those certificates are
> generated by
> > AG developers (after a process request). Can our developer team
> > generate certificates signed by us or it is required your sign?
> > Several people in our university will probably use the system so we
> > would like to have the privilege to generate the certificates. Could
> > someone explain us in a better way, the technical issues behind
> > authentication based on certificates (= how you implemented it)?. I
> > hope you can help us.
> > Thanks in advance,
> > Regards,
> > Luis Galárraga
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20080314/65224b26/attachment.htm>
