[AG-DEV] AG 3.2 RPM pre-beta SVN snapshots for Fedora and RHEL
Todd Zimmerman
toddz at sfu.ca
Fri Jun 20 12:57:11 CDT 2008
Douglas Kosovic wrote:
> Hi,
> AccessGrid-3.2 pre-beta SVN snapshots RPMs for Fedora and RHEL5 can now
> be found here:
> http://www.vislab.uq.edu.au/ag3/fedora/development/RPMS/
One other issue. On two installs now, I get a silent failure of the venueclient after updating.
When running 'VenueClient -d' it turns out it fails with a:
IOError: [Error 13] Permission denied: '/home/tz/.AccessGrid3/Caches/venues'
When I check, sure enough, the .AccessGrid3/Caches directory is owned by root with no write
permission to other. After chown'ing this directory recursively everything is fine.
I assume the rpm installation is doing this - can you check on that?
Todd
