[AG-DEV] Creating a new venue with static addressing via commandline
Thomas D. Uram
turam at mcs.anl.gov
Wed Apr 23 22:33:09 CDT 2008
Lester:
You have two options:
- When creating the Venue, you can include stream descriptions for your
streams, setting the 'static' attribute.
- After creating the Venue, you can call
VenueIW(venueUrl).AddStream(streamDescription) for each stream you want
to add. In this case, too, you'll want to set the static attribute in
the stream description(s).
If you want the VenueServer/Venue to allocate the stream addresses, then
you can call VenueIW(venueUrl).AllocateMulticastLocation. Note that
this only allocates the address, it does not add it to the Venue streams.
Tom
On 4/23/08 6:46 AM, lester leong wrote:
> Hi,
> Does anyone know how I can create a new venue with static addressing
> using python commandline?
> Basically what I wish to achieve is smiliar to the following actions
> on the Venue Server GUI:
> 1) "Add" a new Venue
> 2) "Generate New Addresses" and static addressing
> Currently I have a python code that has the following codes to create
> a new venue:
> newRoomDescription = VenueDescription( roomName, roomDescription, (
> encryptMedia, encryptKey) )
> venueServer = VenueServerIW( serverURL )
> newVenue = venueServer.AddVenue( newRoomDescription )
> The above works just fine. But I am unsure on how I can create with
> static addressing and generating the new addresses.
> Any advise?
> Thanks :-)
> Cheers
> lest
