[AG-DEV] Identity certificates
Luis Galárraga
lgalarra at fiec.espol.edu.ec
Fri Apr 4 15:15:54 CDT 2008
At this moment, I am doing some tests with AG services using a ZSI client
and everything was successful. Now I looking for examples of java clients
consuming zsi web services to discover what is wrong with our java code.
Luis,
2008/4/2, Luis Galárraga <lgalarra at fiec.espol.edu.ec>:
> No, because the program crashes at
> org.apache.axis2.client.OperationClient.execute that is when the soap
> message is sent. wsdl2java generates by default synchronous and asynchronous
> calls. We have tested the synchronous versions and the program always
> crashes at that point.
> 2008/4/2, Thomas D. Uram <turam at mcs.anl.gov>:
> > Are you able to view the SOAP data being returned by the VenueServer to
> > your code?
> > On 4/2/08 2:39 PM, Luis Galárraga wrote:
> > Greetings Tom:
> > We have not been able to consume the services yet. I have generated stub
> > and test classes for VenueServer, Venue and VenueClient interfaces. We have
> > started by testing the simplest methods: Checkpoint and GetVersion (they are
> > configured to be accessed by everybody). Using VenueServer or VenueClient, I
> > get:
> > Exception in thread "main" org.apache.axis2.AxisFault: Processing
> > > Failure
> > > at
> > > org.apache.axis2.util.Utils.getInboundFaultFromMessageContext(Utils.java:486)
> > > at
> > > org.apache.axis2.description.OutInAxisOperationClient.handleResponse(OutInAxisOperation.java:343)
> > > at
> > > org.apache.axis2.description.OutInAxisOperationClient.send(OutInAxisOperation.java:389)
> > > at
> > > org.apache.axis2.description.OutInAxisOperationClient.executeImpl(OutInAxisOperation.java:211)
> > > at
> > > org.apache.axis2.client.OperationClient.execute(OperationClient.java:163)
> > > at
> > > org.accessgrid.www.v3_0.venueclient.VenueClientStub.GetVersion(VenueClientStub.java:3587)
> > > at
> > > test.org.accessgrid.www.v3_0.venueclient.VenueClientTest.main(VenueClientTest.java:597)
> > The soap request message is:
> > <?xml version='1.0' encoding='utf-8'?>
> > > <soapenv:Envelope xmlns:soapenv="
> > > http://schemas.xmlsoap.org/soap/envelope/">
> > > <soapenv:Body>
> > > <ns2:CheckpointRequest xmlns:ns2="
> > > http://www.accessgrid.org/v3.0/venueserver">
> > > <ns2:secondsFromNow>12</ns2:secondsFromNow>
> > > </ns2:CheckpointRequest>
> > > </soapenv:Body>
> > > </soapenv:Envelope>
> > Checking the log in the server (in debug mode), I just get:
> > 04/02/08 14:34:56 -1286157424 Hosting ServiceContainer.py:17 ERROR
> > > Processing Failure
> > > None
> > The log message is not verbose and I do not know the code, but I suspect
> > there is something missing in my request.
> > Luis,
> > > Thanks Tom, in fact I am working now in getting the exact SOAP
> > > messages being sent. I will check the log files of the server.
> > > Luis,
> > > > On 4/1/08 5:15 PM, Luis Galárraga wrote:
> > > > Greetings:
> > > > Finally, I could generate stubs for AG soap interfaces
> > > > (CommunityVenueServer, VenueServer, Venue and VenueClient) using wsdl2java
> > > > with files *Binding.wsdl. I used wsdl files located in CVS repository
> > > > instead of requesting wsdl from server. Now I have several questions:
> > > > - There was a file generate.py which I ran and generated extra wsdl
> > > > files: CommunityServerBinding.wsdl and CommunityServerInterface.wsdl. What
> > > > is CommunityServer service for? Searching in Google I understood that it has
> > > > security purposes but reading the generated code I cannot deduce its
> > > > function. Does this service accept requests in the same port as VenueServer?
> > > > You can ignore the CommunityServer code. That was preliminary and
> > > > is not being used.
> > > > - I configured my server (proyectossw.espol.edu.ec:8000) to accept
> > > > GetVersionRequests for everybody. But when I invoked this method for any
> > > > stub, I get the following message (in this case with VenueClientStub. Those
> > > > examples pointed to localhost so I changed them for my server url):
> > > > Failure
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > org.accessgrid.www.v3_0.venueclient.VenueClientStub.GetVersion(VenueClientStub.java:3586)
> > > > at
> > > > test.org.accessgrid.www.v3_0.venueclient.VenueClientTest.testGetVersion(VenueClientTest.java:352)
> > > > at
> > > > test.org.accessgrid.www.v3_0.venueclient.VenueClientTest.main(VenueClientTest.java:584)
> > > > I can't determine anything from this error message, unfortunately.
> > > > Have you looked at the VenueServer log following this call? Can you look at
> > > > the SOAP data between the server and client, to get an idea of the problem?
> > > > Does anybody have an idea? Thanks in advance.
> > > > Luis,
> > > > 2008/3/28, Luis Galárraga <lgalarra at fiec.espol.edu.ec>:
> > > > > It looks like there is a problem with WSDL, as I get the following
> > > > > error when using WSDL2Java, the tool that comes with Axis distribution. I am
> > > > > using the file obtained by requesting
> > > > > https://proyectossw.espol.edu.ec:8000/Venues/default?WSDL
> > > > > The server is using AccessGrid 3.1.
> > > > > $ ./wsdl2java.sh -uri Venue.wsdl Using AXIS2_HOME:
> > > > > > /home/luis/Desktop/axis2-1.3
> > > > > > Using JAVA_HOME: /usr/lib/jvm/java-6-sun-1.6.0.03/
> > > > > > org.apache.axis2.wsdl.codegen.CodeGenerationException: Error parsing WSDL
> > > > > > at
> > > > > > org.apache.axis2.wsdl.codegen.CodeGenerationEngine.<init>(CodeGenerationEngine.java:150)
> > > > > > at
> > > > > > org.apache.axis2.wsdl.WSDL2Code.main(WSDL2Code.java:35)
> > > > > > at
> > > > > > org.apache.axis2.wsdl.WSDL2Java.main(WSDL2Java.java:24)
> > > > > > Caused by: javax.wsdl.WSDLException: WSDLException (at
> > > > > > /definitions/types): faultCode=INVALID_WSDL: Encountered illegal extension
> > > > > > attribute 'targetNamespace'. Extension attributes must be in a namespace
> > > > > > other than WSDL's.
> > > > > > at
> > > > > > com.ibm.wsdl.xml.WSDLReaderImpl.parseExtensibilityAttributes(Unknown Source)
> > > > > > at com.ibm.wsdl.xml.WSDLReaderImpl.parseTypes(Unknown
> > > > > > Source)
> > > > > > at
> > > > > > com.ibm.wsdl.xml.WSDLReaderImpl.parseDefinitions(Unknown Source)
> > > > > > at com.ibm.wsdl.xml.WSDLReaderImpl.readWSDL(Unknown
> > > > > > Source)
> > > > > > Source)
> > > > > > Source)
> > > > > > at
> > > > > > org.apache.axis2.wsdl.codegen.CodeGenerationEngine.readInTheWSDLFile(CodeGenerationEngine.java:286)
> > > > > > at
> > > > > > org.apache.axis2.wsdl.codegen.CodeGenerationEngine.<init>(CodeGenerationEngine.java:105)
> > > > > > ... 2 more
> > > > > Regards,
> > > > > Luis
> > > > > 2008/3/28, Thomas D. Uram <turam at mcs.anl.gov>:
> > > > > > AG2 did rely on the Globus toolkit.
> > > > > > AG3 does not rely on the Globus toolkit. We are using Doc-Lit
> > > > > > SOAP via Python ZSI (pywebsvcs.sourceforge.net). You should be
> > > > > > able to consume these services using other-language SOAP implementations.
> > > > > > If not, something is wrong with our WSDL, ZSI, or your other-language SOAP
> > > > > > implementation. I'll follow up on your other mail regarding the error
> > > > > > message you're getting.
> > > > > > For what it's worth, I know other people have consumed the AG
> > > > > > web services using a Java SOAP implementation (you should be able to find
> > > > > > information about this in the mailing list archives).
> > > > > > Tom
> > > > > > On 3/27/08 6:53 PM, Luis Galárraga wrote:
> > > > > > Thanks a lot for your help!!. We understand AG a little better
> > > > > > now :-)
> > > > > > Another question: we are trying to consume Venue and VenueServer
> > > > > > web services without success. Now, I understand that as AccessGrid relies on
> > > > > > Globus Toolkit (I have heard about it before, but I understand it better) we
> > > > > > need to construct clients compatible with it. Using JAX-WS (used by Netbeans
> > > > > > IDE) is not a good idea. Am I in the right way??
> > > > > > Luis,
> > > > > > 2008/3/27, Thomas D. Uram <turam at mcs.anl.gov>:
> > > > > > > Luis:
> > > > > > > See responses inline.
> > > > > > > On 3/14/08 3:24 PM, Luis Galárraga wrote:
> > > > > > > Greetings Tom:
> > > > > > > First of all, thanks again for your help, I have several
> > > > > > > questions, this time related to server certificates. Do the things we were
> > > > > > > talking about identity certificates apply to server certificates?. We have a
> > > > > > > developer who is working in consuming AG server web services from a Java
> > > > > > > Client. He would like to work at home, but unfortunately our request for
> > > > > > > opening certain tcp ports was denied because of security issues. I told him
> > > > > > > to run server and client in his machine. I had to make a server certificate
> > > > > > > request to be able to run the server first time:
> > > > > > > - Is it possible to omit this step?.
> > > > > > > The server does require a certificate; this requirement cannot
> > > > > > > be avoided.
> > > > > > > - If not, is it possible to create it with a tool like
> > > > > > > openssl. When starting server from terminal, it asks for a certificate.
> > > > > > > You can build up the required certificate state completely
> > > > > > > independent from the Access Grid Developers CA if you want. In that case,
> > > > > > > you'll have to make sure that the CA cert is installed at both the server
> > > > > > > and at client machines. And the CA cert will have to be used to sign the
> > > > > > > certificate used to run the server. This is standard PKI practice, so you
> > > > > > > should be able to find sufficient references online. If you have trouble,
> > > > > > > please ask.
> > > > > > > - Is there a way of exporting a certificate from command line.
> > > > > > > I have a problem with the certificate management tool (it crashes
> > > > > > > unexpectedly. I reported it and there is someone working to provide you a
> > > > > > > better report) so I cannot do it through graphical interface.
> > > > > > > You can use certmgr.py. In some cases, it will be called
> > > > > > > certmgr3.py. After running it, type 'help' for a list of available
> > > > > > > commands.
> > > > > > > Regards,
> > > > > > > Luis
> > > > > > > 2008/3/13, Thomas D. Uram <turam at mcs.anl.gov>:
> > > > > > > > Hi Luis:
> > > > > > > > There are a few things you need to know in this regard:
> > > > > > > > - By default, AG3 venues do not require that clients have a
> > > > > > > > certificate
> > > > > > > > to enter. Venues can be optionally configured to require a
> > > > > > > > certificate,
> > > > > > > > in which case the user must present a certificate that
> > > > > > > > satisfies the
> > > > > > > > access controls on the venue.
> > > > > > > > - You can run your own CA and issue your own
> > > > > > > > certificates. In that
> > > > > > > > case, you'll need to make sure your clients have both your
> > > > > > > > CA
> > > > > > > > certificate and their personal certificate.
> > > > > > > > Otherwise, this is general PKI. If you have other
> > > > > > > > questions, don't
> > > > > > > > hesitate to ask.
> > > > > > > > Tom
> > > > > > > > On 3/6/08 3:41 PM, Luis Galárraga wrote:
> > > > > > > > > Greetings:
> > > > > > > > > I am part of project for developing a webinar
> > > > > > > > infraestructure based on
> > > > > > > > > Access Grid. After a long discussion in which suggestions
> > > > > > > > in this
> > > > > > > > > mailing list were strongly considered, we have decided to
> > > > > > > > implement a
> > > > > > > > > simple client for venues (in servers 3.x) using Java Web
> > > > > > > > Start Apps.
> > > > > > > > > As you can see, there are many things to do, and
> > > > > > > > developers have
> > > > > > > > > started by making tests with the soap interfaces in the
> > > > > > > > our AG server,
> > > > > > > > > however they are not clear about the concepts behind the
> > > > > > > > > authentication process. We know AG uses digital
> > > > > > > > certificates for
> > > > > > > > > everything: users and services and those certificates are
> > > > > > > > generated by
> > > > > > > > > AG developers (after a process request). Can our developer
> > > > > > > > team
> > > > > > > > > generate certificates signed by us or it is required your
> > > > > > > > sign?
> > > > > > > > > Several people in our university will probably use the
> > > > > > > > system so we
> > > > > > > > > would like to have the privilege to generate the
> > > > > > > > certificates. Could
> > > > > > > > > someone explain us in a better way, the technical issues
> > > > > > > > behind
> > > > > > > > > authentication based on certificates (= how you
> > > > > > > > implemented it)?. I
> > > > > > > > > hope you can help us.
> > > > > > > > > Thanks in advance,
> > > > > > > > > Regards,
> > > > > > > > > Luis Galárraga
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20080404/b78f010f/attachment.htm>
