[AG-DEV] SWIG Errors building Common on OS X Tiger
Ed Brannin
edbrannin at gmail.com
Thu May 17 14:26:13 CDT 2007
Hello,
I'm having trouble building AG on my OS X 10.4 system, with Swig
1.3.29 -- if anyone can figure this out (or reproduce, at least) that
would be great.
Everyone else, pardon the spammy-long message. :-)
-Ed Brannin
Writing /Users/ed/Code/AccessGrid/build_svn/dist-20070516_150921/lib/python2.5/site-packages/PACKAGENAME-1.0-py2.5.egg-info
Build finished at: Wed, 16 May 2007 20:12:10 +0000
Completed in 3.50345897675 seconds
*********** Building common
Running swig with: |['swig', '-python', '-outdir', 'common', '-c++',
'-new_repr', '-I/Library/Frameworks/Python.framework/Versions/2.5/include/python2.5',
'-I../../src', '-cpperraswarn', '-o', 'common_wrap.cpp', 'common.i']|
../../src/rtp.h:51: Warning(205): CPP #error "RTP library requires
WORDS_BIGENDIAN or WORDS_SMALLENDIAN to be defined.".
common.i:22: Warning(124): Specifying the language name in %typemap is
deprecated - use #ifdef SWIG<LANG> instead.
common.i:28: Warning(124): Specifying the language name in %typemap is
common.i:38: Warning(124): Specifying the language name in %typemap is
common.i:42: Warning(124): Specifying the language name in %typemap is
common.i:46: Warning(124): Specifying the language name in %typemap is
common.i:50: Warning(124): Specifying the language name in %typemap is
common.i:54: Warning(124): Specifying the language name in %typemap is
common.i:58: Warning(124): Specifying the language name in %typemap is
running clean
removing 'build/temp.macosx-10.3-fat-2.5' (and everything under it)
removing 'build/lib.macosx-10.3-fat-2.5' (and everything under it)
'build/bdist.macosx-10.3-fat' does not exist -- can't clean it
'build/scripts-2.5' does not exist -- can't clean it
removing 'build'
Build finished at: Wed, 16 May 2007 20:12:12 +0000
Completed in 1.41529512405 seconds
running build
running build_py
creating build
creating build/lib.macosx-10.3-fat-2.5
creating build/lib.macosx-10.3-fat-2.5/common
copying common/__init__.py -> build/lib.macosx-10.3-fat-2.5/common
copying common/common.py -> build/lib.macosx-10.3-fat-2.5/common
copying common/RTPBeacon.py -> build/lib.macosx-10.3-fat-2.5/common
copying common/RTPSensor.py -> build/lib.macosx-10.3-fat-2.5/common
copying common/scheduler.py -> build/lib.macosx-10.3-fat-2.5/common
running build_ext
building '_common' extension
creating build/temp.macosx-10.3-fat-2.5
gcc -arch ppc -arch i386 -isysroot /Developer/SDKs/MacOSX10.4u.sdk
-fno-strict-aliasing -Wno-long-double -no-cpp-precomp -mno-fused-madd
-fno-common -dynamic -DNDEBUG -g -O3
-I/Users/ed/Code/AccessGrid/build_svn/common/src
-c common_wrap.cpp -o build/temp.macosx-10.3-fat-2.5/common_wrap.o
common_wrap.cpp: In function 'int
SWIG_Python_ConvertFunctionPtr(PyObject*, void**, swig_type_info*)':
common_wrap.cpp:2051: error: invalid conversion from 'const char*' to 'char*'
common_wrap.cpp: In function 'int SWIG_AsCharPtrAndSize(PyObject*,
char**, size_t*, int*)':
common_wrap.cpp:2622: error: invalid conversion from 'int*' to 'Py_ssize_t*'
common_wrap.cpp:2622: error: initializing argument 3 of 'int
PyString_AsStringAndSize(PyObject*, char**, Py_ssize_t*)'
common_wrap.cpp: In function 'void
SWIG_Python_FixMethods(PyMethodDef*, swig_const_info*,
swig_type_info**, swig_type_info**)':
common_wrap.cpp:9970: error: invalid conversion from 'const char*' to 'char*'
lipo: can't figure out the architecture type of: /var/tmp//ccCAkyAz.out
error: command 'gcc' failed with exit status 1
Build of Python module common/examples/_common failed
/Library/Frameworks/Python.framework/Versions/2.5/Resources/Python.app/Contents/MacOS/Python
BuildPythonModules.py /Users/ed/Code/AccessGrid/build_svn
/Users/ed/Code/AccessGrid/build_svn/AccessGrid-20070516_150921
/Users/ed/Code/AccessGrid/build_svn/dist-20070516_150921 failed with
256; exiting
rake aborted!
Command failed with status (1): [python BuildSnapshot.py ]
/Users/ed/Code/AccessGrid/build_svn/rakefile:123
(See full trace by running task with --trace)
wireless-111-15:~/Code/AccessGrid/build_svn ed$ swig -v
Must specify an input file. Use -help for available options.
wireless-111-15:~/Code/AccessGrid/build_svn ed$ swig --version
Unable to find option or file '--version', use 'swig -help' for more
information.
wireless-111-15:~/Code/AccessGrid/build_svn ed$ swig -version
SWIG Version 1.3.29
Compiled with /usr/bin/g++-4.0 [i686-apple-darwin8.8.1]
Please see http://www.swig.org for reporting bugs and further information
wireless-111-15:~/Code/AccessGrid/build_svn ed$ which swig
/opt/local/bin/swig
