[AG-DEV] Running AG from CVS - missing scripts?
Andrew Ford
acf0659 at rit.edu
Thu Mar 15 14:45:31 CDT 2007
I'm currently trying to run Access Grid directly from a source tree checked
out from CVS as described in README-developers, but I'm having issues with
the configuration setup when running CvsSetup.py - when it gets to the
generating interfaces step, it essentially fails since it can't find
wsdl2py.py & wsdl2dispatch.py (it doesn't error out, but Access Grid won't
start due to: ImportError: No module named AGNodeService_client since that's
in interfaces). These python files apparently exist in an actual build of AG
but they're completely absent from a CVS checkout. I'd really rather be able
to run right from a CVS checkout instead of doing some sort of hackish
copy-script-from-dummy-build thing. Does anyone have any experience with
this?
--Andrew
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20070315/fcdf5c89/attachment.htm>
