[AG-DEV] Access Grid 3.0 Release Available
Thomas D. Uram
turam at mcs.anl.gov
Thu May 4 13:20:12 CDT 2006
Could you provide some more information? We haven't seen this be a problem
on other Windows machines. Logfiles would be very helpful.
Tom
On 5/4/06 5:48 AM, Andrew A Rowley wrote:
> Hi,
> I installed this, and it worked, but vic and rat were not starting in the venue. I found that the Logs contained the line
> "%1 is not a valid application"
> On looking in AccessGrid\Platform\win32\ProcessManager.py I found that the problem was that while the arguments with spaces were put in inverted commas, the same was not true for the command.
> So I added:
> if command.find(" ") != -1:
> command = '"' + command + '"'
> to the start of the StartProcess function (line 46). This seems to make it work again.
> Andrew :)
> Access Grid Support Centre,
> RSS Group,
> Manchester Computing,
> Kilburn Building,
> University of Manchester,
> Oxford Road,
> Manchester,
> M13 9PL,
> UK
> Tel: +44(0)161-275 0685
> Email: Andrew.Rowley at manchester.ac.uk
>> -----Original Message-----
>> From: owner-ag-dev at mcs.anl.gov [mailto:owner-ag-dev at mcs.anl.gov] On Behalf
>> Of Thomas D. Uram
>> Sent: 03 May 2006 17:00
>> To: ag-dev at mcs.anl.gov
>> Subject: [AG-DEV] Access Grid 3.0 Release Available
>> The Access Grid 3.0 software is available for download at:
>> http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/3.0
>> This is a major new release of the Access Grid software. (Note that AG3
>> is not compatible with AG2 releases; specifically, AG3 clients and servers
>> do not work with AG2 clients and servers.)
>> Release Highlights
>> o Jabber client integration
>> o Integrated meeting schedule viewer
>> o Improved venue navigation
>> + View all Venues on server, exits from current Venue, or
>> MyVenues
>> + Tree-based perusal of Venue space (without entering)
>> o Added VenueClient user preferences
>> o Certificate no longer required by VenueClient
>> o Improved control of media tools through VenueClient
>> o Multicast indicator on VenueClient
>> o Integrated per-Venue Multicast Beacon client
>> o Integrated beacon matrix
>> o New bridging facility (available in any venue)
>> o Encrypted network communications throughout
>> o Simplified node configuration through discovery of node
>> services
>> and service managers on the local subnet (via Bonjour)
>> o RAT: silence suppression off by default
>> o VIC: stale streams time out and are removed
>> o VIC: try to match source port to destination port before
>> using
>> ephemeral port as source (simplifies firewall handling for
>> vic)
>> o Windows users: WDM capture device support, enabling use of
>> capture cards with newer drivers (e.g. Winnov, iTuner)
>> For full information on this release, and a complete listing of the bugs
>> fixed, see the official release page. For a tour of the new
>> functionality,
>> refer to the testing tips at
>> http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/3.0/testin
>> g.html
>> As part of this release, the default AG3 venue server at
>> https://vv3.mcs.anl.gov:8000/Venues/default
>> has been updated to the released AG3 code. Note that AG3 beta Venue
>> Clients are incompatible with this server.
>> As always, user feedback is welcome. Please file feature requests, bug
>> reports, and enhancements via the Access Grid Bugzilla page at
>> http://bugzilla.mcs.anl.gov/accessgrid.
>> Thanks,
>> The AG Developers
