[AG-DEV] Access Grid 3.0 Release Available
Andrew A Rowley
Andrew.Rowley at manchester.ac.uk
Thu May 4 05:48:24 CDT 2006
I installed this, and it worked, but vic and rat were not starting in the venue. I found that the Logs contained the line
"%1 is not a valid application"
On looking in AccessGrid\Platform\win32\ProcessManager.py I found that the problem was that while the arguments with spaces were put in inverted commas, the same was not true for the command.
So I added:
if command.find(" ") != -1:
command = '"' + command + '"'
to the start of the StartProcess function (line 46). This seems to make it work again.
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message-----
> From: owner-ag-dev at mcs.anl.gov [mailto:owner-ag-dev at mcs.anl.gov] On Behalf
> Of Thomas D. Uram
> Sent: 03 May 2006 17:00
> To: ag-dev at mcs.anl.gov
> Subject: [AG-DEV] Access Grid 3.0 Release Available
> The Access Grid 3.0 software is available for download at:
> http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/3.0
> This is a major new release of the Access Grid software. (Note that AG3
> is not compatible with AG2 releases; specifically, AG3 clients and servers
> do not work with AG2 clients and servers.)
> Release Highlights
> o Jabber client integration
> o Integrated meeting schedule viewer
> o Improved venue navigation
> + View all Venues on server, exits from current Venue, or
> MyVenues
> + Tree-based perusal of Venue space (without entering)
> o Added VenueClient user preferences
> o Certificate no longer required by VenueClient
> o Improved control of media tools through VenueClient
> o Multicast indicator on VenueClient
> o Integrated per-Venue Multicast Beacon client
> o Integrated beacon matrix
> o New bridging facility (available in any venue)
> o Encrypted network communications throughout
> o Simplified node configuration through discovery of node
> services
> and service managers on the local subnet (via Bonjour)
> o RAT: silence suppression off by default
> o VIC: stale streams time out and are removed
> o VIC: try to match source port to destination port before
> using
> ephemeral port as source (simplifies firewall handling for
> vic)
> o Windows users: WDM capture device support, enabling use of
> capture cards with newer drivers (e.g. Winnov, iTuner)
> For full information on this release, and a complete listing of the bugs
> fixed, see the official release page. For a tour of the new
> functionality,
> refer to the testing tips at
> http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/3.0/testin
> g.html
> As part of this release, the default AG3 venue server at
> https://vv3.mcs.anl.gov:8000/Venues/default
> has been updated to the released AG3 code. Note that AG3 beta Venue
> Clients are incompatible with this server.
> As always, user feedback is welcome. Please file feature requests, bug
> reports, and enhancements via the Access Grid Bugzilla page at
> http://bugzilla.mcs.anl.gov/accessgrid.
> Thanks,
> The AG Developers
