[AG-DEV] Segmerntation fault with SharedPresentation
Douglas Kosovic
douglask at itee.uq.edu.au
Tue Mar 21 23:35:01 CST 2006
Hi Claus,
> The version of OpenOffice I am running is current for FC4 as of
> last week, 2.0.1.1-5.1. An attempt to upgrade to the version in
> the "development" repository fails due to unresolved dependencies.
Possibly adding a time.sleep(1) call before the
com.sun.star.bridge.UnoUrlResolver line in
/etc/AccessGrid/SharedApplications/Shared_Presentation/ImpressViewer.py
might solve the problem. As I'm not able to reproduce the bug, I can't
confirm.
> Should I try everything under FC5?
I don't know if that would help.
> I could not find anything in OpenOffice bugzilla that would indicate a
> fix.
Fedora doesn't use the OpenOffice.org version, but the one from
http://ooo.ximian.com/ which is what most linux distrbutions that ship
OpenOffice use, it consists of a heap of patches that get applied to the
official OpenOffice.org version, then the Fedora version applies more
patches on top of those. I thought one of the patches included the mutex
patch, but looks like I was mistaken.
The only other alternative I could think of is to download the OpenOffice
SRPM and manually applying the GlobalMutex fix to the PyUNO source code,
unfortunatelly building OpenOffice is a bitch as it has a weird build
infrastucture.
Cheers,
Doug
> Douglas Kosovic wrote:
>> Hi Claus,
>>> When trying to Open a SharedPresentation, ImpressViewer.py
>>> dies with a segmentation fault in resolver.resolve(..).
>>> Operating System: Fedora Core 4 i386 smp
>>> Hardware: AMD64-X2 dual core
>>> Access-Grid 2.4-6
>>> The stack is exactly like described in
>>> http://www.oooforum.org/forum/viewtopic.phtml?t=31824 titled
>>> "XUnoUrlResolver crashes while resolving a URL".
>>> The solution for the problem in the post, which shows the
>>> crash using C++, is to obtain a GlobalMutex.
>>> This would obviously be different under python.
>>> Can anybody help? This is a show-stopper for shared presentations.
>> Have you updated your copy of OpenOffice? I believe later versions of the
>> PyUNO bridge are already using a osl::MutexGuard with that method call. I
>> don't think the OpenOffice mutex infrastructure is visible from with
>> Python.
>> Cheers,
>> Doug
> Claus Endres | Phone: +61-3-5998 2310
> Endres Consulting Pty. Ltd. | Mobile: +61-418-595 136
> 10 Facey Road | Fax: +61-3-5998 2540
> Devon Meadows, VIC 3977 | claus at endresconsulting.com
