[AG-DEV] Segmerntation fault with SharedPresentation
Claus Endres
claus at endresconsulting.com
Tue Mar 21 20:20:04 CST 2006
Hi Doug,
The version of OpenOffice I am running is current for FC4 as of
last week, 2.0.1.1-5.1. An attempt to upgrade to the version in
the "development" repository fails due to unresolved dependencies.
Should I try everything under FC5?
I could not find anything in OpenOffice bugzilla that would
indicate a fix.
Claus.
Douglas Kosovic wrote:
> Hi Claus,
>> When trying to Open a SharedPresentation, ImpressViewer.py
>> dies with a segmentation fault in resolver.resolve(..).
>> Operating System: Fedora Core 4 i386 smp
>> Hardware: AMD64-X2 dual core
>> Access-Grid 2.4-6
>> The stack is exactly like described in
>> http://www.oooforum.org/forum/viewtopic.phtml?t=31824 titled
>> "XUnoUrlResolver crashes while resolving a URL".
>> The solution for the problem in the post, which shows the
>> crash using C++, is to obtain a GlobalMutex.
>> This would obviously be different under python.
>> Can anybody help? This is a show-stopper for shared presentations.
> Have you updated your copy of OpenOffice? I believe later versions of
> the PyUNO bridge are already using a osl::MutexGuard with that method
> call. I don't think the OpenOffice mutex infrastructure is visible from
> with Python.
> Cheers,
> Doug
Claus Endres | Phone: +61-3-5998 2310
Endres Consulting Pty. Ltd. | Mobile: +61-418-595 136
10 Facey Road | Fax: +61-3-5998 2540
Devon Meadows, VIC 3977 | claus at endresconsulting.com
