[AG-DEV] Running AG3 From CVS on RHEL4 Experiences
Thomas D. Uram
turam at mcs.anl.gov
Wed Mar 1 13:50:41 CST 2006
On 3/1/06 1:32 PM, Todd Zimmerman wrote:
> I should have noted - this _wasn't_ meant to be rant! Sorry if it came across that way. Just trying
> to get a test VenueServer up...
I took it as thorough documentation of problems. Thanks!
Some of your dependencies are older that what we've been using.
You can find a list here:
http://www.mcs.anl.gov/fl/research/accessgrid/wiki/moin.cgi/AccessGrid3Dependencies
Sorry for the confusion. A couple notes:
- ZSI: The release candidate will fix the wsdl2py/wsdl2py.py problem you
mentioned.
- openssl: I'm not sure how far back we can go, but I know there were security
related fixes
in the latest releases of both 0.9.7 and 0.9.8
- Twisted: We only use twisted.internet, which you can get as a separate (and
smaller) bundle
- Bajjer: 0.2.4 fixes a bug which caused the VenueClient to crash on Linux
- M2Crypto must be 0.15 (this will fix the problem with
ssl_ctx_load_verify_locations)
I wouldn't hesitate to file bugs for issues you find. It creates a record of a
problem found
and the solution (even if the solution is "this is not a problem because xyz").
Tom
> For completeness, here are the versions of the pre-reqs:
> Python 2.3.4
> ZSI (from cvs) 1.7 released 16-Feb-2005
> Bajjer-0.2.3
> Twisted-2.2.0 (TwistedSumo-02006-02-12)
> ZopeInterface-3.0.1
> common - From CVS Feb 21
> feedparser-4.1
> mDNSResponder-107.5
> Bonjour Python module from CVS Feb 21
> openssl-0.9.7a-43.4
> pyOpenSSL version 0.5.1 from CVS Feb 21
> M2Crypto 0.13
> Todd
>> Just wanted to document my experiences with running AG3 from CVS on RH EL 4.
>> I started by downloading/installing all the pre-requisites, including rebuilding the wxPython rpms
>> from the wxPython site (to get the 2.6 versions). Then I checked out the sources from CVS, cd'd
>> into AccessGrid/tools and ran 'python CvsSetup.py -a ..' as per the instructions at
>> http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/cvs.html.
>> The rat build (main_control.c) failed citing 'conflicting types for snprintf'. Looks like the
>> config script declared that snprintf wasn't available so it was redeclared/rewritten in the code via
>> an ifdef. I just altered the ifdef to fail (and thus not redeclare) and the build worked.
>> Another problem was at the end of the build - there is a series of errors:
>> Generating Interfaces
>> sh: wsdl2py.py: command not found
>> sh: wsdl2dispatch.py: command not found
>> Upon investigation, there doesn't seem to be a wsdl2py.py on my system - including in the newly
>> built packages - however, /usr/bin/wsdl2py and /usr/bin/wsdl2dispatch (note no .py) do exist - so I
>> changed the GenerateInterfaces.py script exec variables to be wsdl2py and wsdl2dispatch and that
>> seemed to do the trick.
>> I then sourced the env-init.sh script and started VenueClient.py.
>> Up popped the Enter Profile Info dialog - I entered data pressed OK and it crashed:
>> File "/home/toddz/src/AccessGrid/AccessGrid/Jabber/JabberClient.py", line 86, in SendNameChange
>> presence.from_ = self.currentRoomId + '/' + self.name
>> TypeError: cannot concatenate 'str' and 'NoneType' objects
>> Changed the declaration of self.name (line 26) from = none to = '' (str type).
>> Restarted VenueClient - now complained of a AttributeError: JabberClient instance has no attribute
>> '_stream' and upon checking, sure enough Line 20 shows _stream commented out. I tried uncommenting
>> and ran in another error (about one of the parameters 'host' not being defined).
>> Since I was trying to set up a VenueServer and was only starting the VenueClient to test, I gave up
>> on my efforts and instead concentrated on getting the VenueServer running.
>> Ran CertificateManager.py and imported by ANL VenueServer service cert.
>> Then started VenueServer.py -d. Here's the end of the trace:
>> Traceback (most recent call last):
>> File "./VenueServer.py", line 144, in ?
>> main()
>> File "./VenueServer.py", line 98, in main
>> context = Toolkit.Service.instance().GetContext()
>> File "/home/toddz/src/AccessGrid/AccessGrid/Toolkit.py", line 217, in GetContext
>> self.__context.load_verify_locations(capath=caDir)
>> File "/usr/lib/python2.3/site-packages/M2Crypto/SSL/Context.py", line 121, in load_verify_locations
>> return m2.ssl_ctx_load_verify_locations(self.ctx, cafile, capath)
>> TypeError: ssl_ctx_load_verify_locations() argument 2 must be string, not None
>> Changed line 217 in GetContext to read self.__context.load_verify_locations('', capath=caDir)
>> and the VenueServer started fine.
>> Only issue now is that I can't connect with the VenueManagement tool.... but I've already documented
>> that issue in my email to ag-dev from Feb 22.
>> Are these known issues?? I hate to file bug reports if the bug is caused by my (mis) configuration...
>> All of the pre-req's were taken from the AG download site and I'm running Python 2.3.4.
>> Thanks!
>> Todd
