[AG-DEV] AG3: VenueClient doesn't start anymore
Thomas D. Uram
turam at mcs.anl.gov
Wed Jan 25 16:31:53 CST 2006
Chris:
You should find the current state much better. There was an error in
initialization of
a user's certificate repository that caused the VenueServer/VenueManagement
problem.
If you remove the certificate repository, it will now be properly initialized
and things should
work.
We've fixed a number of other problems, too. This VenueClient problem may
still occur,
but I had it mostly resolved last night and hope to finish it off this evening.
If you could try to build a package and let us know if you run into
difficulties, it'd be appreciated.
Your testing is a big help.
Tom
On 1/23/06 5:20 PM, Christoph Willing wrote:
> Working from packaged version of this morning's CVS, VenueClient gets
> stuck before showing UI. Log file says:
> 01/24/2006 09:07:01 AM -1211799328 Toolkit Config.py:559 DEBUG
> System hostname of v2.vislab.uq.edu.au is valid
> 01/24/2006 09:07:01 AM -1211799328 Toolkit Toolkit.py:106 DEBUG
> Initializing AG Toolkit version 3.0
> 01/24/2006 09:07:01 AM -1211799328 Toolkit Toolkit.py:107 INFO
> Command and arguments: ['/usr/bin/VenueClient.py']
> 01/24/2006 09:07:01 AM -1211799328 Platform Config.py:595 INFO gnome
> directory /home/ag/.gnome/application-info or /home/ag/.gnome/mime-info
> not found, not registering file type .agpkg with gnome
> not found, not registering file type .vv2d with gnome
> 01/24/2006 09:07:01 AM -1211799328 VenueClient Preferences.py:166
> DEBUG Preferences.LoadPreferences: open file
> 01/24/2006 09:07:01 AM -1211799328 Toolkit Toolkit.py:156 INFO
> Logfile Name: VenueClient.log
> 01/24/2006 09:07:01 AM -1211799328 Toolkit VenueClient.py:80 INFO wx
> version is: 2.6.2.1
> 01/24/2006 09:07:01 AM -1211799328 VenueClient VenueClient.py:1356
> DEBUG SetNodeUrl: Set node service url: http://localhost:11000/NodeService
> 01/24/2006 09:07:01 AM -1211799328 VenueClient VenueClient.py:311
> DEBUG __StartWebService: venueclient:
> http://v2.vislab.uq.edu.au:11000/VenueClient
> 01/24/2006 09:07:01 AM -1211799328 VenueClient VenueClient.py:322
> DEBUG __StartWebService: service manager:
> http://v2.vislab.uq.edu.au:11000/ServiceManager
> 01/24/2006 09:07:01 AM -1211799328 VenueClient VenueClient.py:336
> DEBUG __StartWebService: node service:
> http://v2.vislab.uq.edu.au:11000/NodeService
> 01/24/2006 09:07:01 AM -1211799328 VenueClient Preferences.py:236
> ERROR Preferences:GetNodeConfigs: Failed to get node service
> configurations.
> Traceback (most recent call last):
> File "/usr/lib/python2.4/site-packages/AccessGrid/Preferences.py",
> line 234, in GetNodeConfigs
> configs = nservice.GetConfigurations()
> File
> "/usr/lib/python2.4/site-packages/AccessGrid/interfaces/AGNodeService_client.py",
> line 82, in GetConfigurations
> self.binding.Send(None, None, request,
> soapaction="urn:#GetConfigurations", **kw)
> File "/usr/lib/python2.4/site-packages/ZSI/client.py", line 251, in Send
> self.h.connect()
> File "/usr/lib/python2.4/httplib.py", line 626, in connect
> raise socket.error, msg
> error: (111, 'Connection refused')
> 01/24/2006 09:07:01 AM -1211799328 VenueClient VenueClient.py:356
> DEBUG Null default node configuration, not loading
> An interesting(?) feature of that error is how similar it is to the
> VenueManagement connection problem previously mentioned - when trying to
> connect to the VenueServer at localhost, the error is:
> 01/24/2006 09:05:13 AM -1211594528 VenueManagement
> VenueManagement.py:389 DEBUG VenueManagementClient.ConnectToServer:
> Connect to server https://localhost:8000/VenueServer
> VenueManagement.py:397 DEBUG VenueManagementClient.ConnectToServer:
> Connect to server
> VenueManagement.py:404 DEBUG VenueManagementClient.ConnectToServer: Get
> venues from server
> VenueManagement.py:488 ERROR VenueManagementClient.ConnectToServer: Can
> not connect.:
> File "/usr/bin/VenueManagement.py", line 407, in ConnectToServer
> vl = self.server.GetVenues()
> File
> "/usr/lib/python2.4/site-packages/AccessGrid/interfaces/VenueServer_client.py",
> line 158, in GetVenues
> self.binding.Send(None, None, request, soapaction="urn:#GetVenues",
> **kw)
> self.h.connect()
> File "/usr/lib/python2.4/httplib.py", line 1068, in connect
> sock.connect((self.host, self.port))
> File "<string>", line 1, in connect
> chris
