[AG-DEV] AG3 VenueManagement can't connect
Thomas D. Uram
turam at mcs.anl.gov
Mon Jan 23 09:33:10 CST 2006
Ok, I haven't been able to reproduce the problem, but Eric has seen this problem.
We'll get back to you today with a fix.
Tom
On 1/21/06 3:07 AM, Christoph Willing wrote:
> On 21/01/2006, at 6:53 AM, Thomas D. Uram wrote:
>> Chris:
>> This line occurs repeatedly:
>> sslerror: (1, 'error:14094418:SSL routines:SSL3_READ_BYTES:tlsv1
>> alert unknown ca')
>> Do you have the appropriate CA certs in the cert repository?
> Tom,
> I have:
> ag at v2:~$ ls -l /etc/AccessGrid3/Config/CAcertificates/
> total 32
> -rw-r--r-- 1 ag ag 1436 2004-04-20 08:00 1c3f2ca8.0
> -rw-r--r-- 1 ag ag 2276 2004-05-07 04:51 1c3f2ca8.signing_policy
> -rw-r--r-- 1 ag ag 904 2004-03-26 00:25 45cc9e80.0
> -rw-r--r-- 1 ag ag 1334 2004-03-26 00:25 45cc9e80.signing_policy
> -rw-r--r-- 1 ag ag 1448 2004-04-20 08:00 d1b603c3.0
> -rw-r--r-- 1 ag ag 2263 2004-03-26 00:25 d1b603c3.signing_policy
> -rw-r--r-- 1 ag ag 1334 2004-09-06 15:26 f18fa857.0
> -rw-r--r-- 1 ag ag 571 2004-09-06 15:26 f18fa857.signing_policy
>> I'm ignoring the 'connection refused' errors, because I expect either
>> the server wasn't
>> running, or was running on a different network interface.
> The venue server was running; there's only one network interface on the
> machine.
> chris
>> On 1/20/06 2:37 PM, Christoph Willing wrote:
>>> On 21/01/2006, at 3:03 AM, Thomas D. Uram wrote:
>>>> Is there mention of the default certificate in VenueManagement.log?
>>>> If details there aren't clear, I'd sure be interested to see the log.
>>> Tom,
>>> A log of yesterday's attempts is attached. It includes attempts
>>> with server running secure mode then insecure mode, although I
>>> don't know if thats evident from the log. It also shows the
>>> different server names used (localhost & fqdn).
>>> The default certificate is mentioned a few times (at each start up
>>> I guess). Since VenueServer and VenueManagement are running on the
>>> same machine, each is using the same default cert, which mostly
>>> happens to be a server certificiate, although you'll see near the
>>> end that I also tried using an Anonymous User cert too.
>>> chris
>>>> On 1/19/06 10:25 PM, Christoph Willing wrote:
>>>>> On 20/01/2006, at 2:01 PM, Thomas D. Uram wrote:
>>>>>> Is your default certificate an identity certificate (i.e., does
>>>>>> it require a passphrase?).
>>>>>> That's not being handled currently. If so, try using a service
>>>>>> certificate instead.
>>>>>> If not, something's wrong.
>>>>> Tom,
>>>>> Its a VenueServer certificate, borrowed from another machine,
>>>>> and same result using an anonymous certificate.
>>>>> ag at v2:~$ certmgr.py
>>>>> (ID mode) > list
>>>>> 1. (Default) /O=Access Grid/OU=agdev-ca.mcs.anl.gov/
>>>>> CN=VenueServer/ seivers.vislab.uq.edu.au
>>>>> 2. /O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab
>>>>> Anonymous Authority/CN=Anonymous User
>>>>> 486c88f05354caa6e542b09b19cdee01
>>>>> (ID mode) > show 1
>>>>> Subject: /O=Access Grid/OU=agdev-ca.mcs.anl.gov/ CN=VenueServer/
>>>>> Issuer: /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid
>>>>> Developers CA
>>>>> Certificate version: 2
>>>>> Serial number: 5778
>>>>> Not valid before: 03/18/05 01:41:35
>>>>> Not valid after: 03/18/06 01:41:35
>>>>> MD5 Fingerprint: 2A:81:9C:98:C2:76:09:1F:6C:E9:3E:47:B7:99:65:65
>>>>> Certificate location: /home/ag/.AccessGrid3/Config/certRepo/
>>>>> certificates/9c833de531fe7da7cff5bbfeaaf770fc/
>>>>> 1c291311d25c9e1f2a79b98047ad6fec/cert.pem
>>>>> Private key location: /home/ag/.AccessGrid3/Config/certRepo/
>>>>> privatekeys/2f30fa4ccf0c09b08e4b9050829bc33b.pem
>>>>>> On 1/19/06 7:30 PM, Christoph Willing wrote:
>>>>>>> Working with a packaged AG3, I can run the VenueServer and
>>>>>>> connect to it with a VenueClient. However I can't connect to
>>>>>>> it with the VenueManagement tool. Trying to connect (from
>>>>>>> same machine) with:
>>>>>>> https://localhost/VenueServer
>>>>>>> or https://v2.vislab.uq.edu.au/VenueServer
>>>>>>> both immediately result in a "Unable To Connect" popup msg box
>>>>>>> saying:
>>>>>>> You were unable to connect to the venue server at:
>>>>>>> https://v2.vislab.uq.edu.au/VenueServer.
>>>>>>> The VenueServer.log doesn't mention anything about a
>>>>>>> connection attempt in such cases.
>>>>>>> If I then add a :8000 to the url, the following error is added
>>>>>>> to VenueServer.log:
>>>>>>> 01/20/06 11:27:29 -1273504848 Hosting ServiceContainer.py:
>>>>>>> 146 ERROR None
>>>>>>> Traceback (most recent call last):
>>>>>>> File "/usr/lib/python2.4/site-packages/M2Crypto/SSL/
>>>>>>> SSLServer.py", line 29, in handle_request
>>>>>>> request, client_address = self.get_request()
>>>>>>> File "/usr/lib/python2.4/SocketServer.py", line 373, in
>>>>>>> get_request
>>>>>>> return self.socket.accept()
>>>>>>> Connection.py", line 114, in accept
>>>>>>> ssl.accept_ssl()
>>>>>>> Connection.py", line 103, in accept_ssl
>>>>>>> return m2.ssl_accept(self.ssl)
>>>>>>> SSLError: no certificate returned
> Christoph Willing +61 7 3365 8350
> QPSF Access Grid Manager
> University of Queensland
