[AG-DEV] AccessGrid3.interfaces??
Christoph Willing
willing at itee.uq.edu.au
Fri Jan 13 06:01:16 CST 2006
On 13/01/2006, at 7:41 PM, Michael Braitmaier wrote:
> You should get the interfaces directory when running CVSSetup.py -a
> from the tools directory.
> This way the wsdl files from the wsdl directory are compiled to
> python files which are put into a directory called interfaces.
> These files provide the "stubs" for the webservices, as far as I
> understood it.
Thanks Michael. If that is the case, then this step (or something
similar that produces the interfaces directory) is missing from
AccessGrid/setup.py and needs to be added. I gather running
CVSSetup.py is necessary to run live from CVS, but its never been
part of the packaging procedure so far.
chris
> Christoph Willing schrieb:
>> I'm just starting to look at building AccessGrid/packaging/
>> BuildSnapshot.py
>> The first problem is when it runs AccessGrid/setup.py, where there
>> is a list named 'packages' containing an element
>> AccessGrid3.interfaces. All the elements in that list have a
>> corresponding directory with the same name, however there is no
>> interfaces directory.
>> Am I missing an interfaces directory, or can I safely remove
>> AccessGrid3.interfaces from the list?
>> chris
>> Christoph Willing +61 7 3365 8350
>> QPSF Access Grid Manager
>> University of Queensland
> Dipl.-Inf. Michael Braitmaier
> HLRS - Visualization / Video Conferencing
> University of Stuttgart
> Germany
> Phone: ++49 711 685 5996
> Fax : ++49 711 682 357
> Website: http://www.hlrs.de/people/braitmaier/
