[AG-DEV] AG3 Shared App Migration - EventID
Todd Zimmerman
toddz at sfu.ca
Wed Aug 30 11:20:06 CDT 2006
hmmm I'm using AccessGrid-3.0.2-1.fc5
Could you tell me what particular file the bug was in - then I'll replace it with the cvs version to
test. In the meantime, I'll see if I can get Doug to build me a newer rpm.
Todd
Susanne Lefvert wrote:
> Hello Todd,
> Which version of the software are you using? The event.GetSenderId()
> should return the public id of the sender. We did have a bug in the
> software that sounds like the problem you are describing, that
> particular bug was fixed in 3.0.2. If you are running earlier versions
> of the software, I would recommend updating.
> Susanne
> On Aug 25, 2006, at 6:01 PM, Todd Zimmerman wrote:
>> Hi Susanne,
>> Thanks for the help!
>> One further clarification. The page you referenced indicates to use
>> "the new event method
>> event.GetSenderId() to retrieve the public id of a sender" but this
>> doesn't seem to be the public Id
>> of the sender (from the user's profile).
>> Further, it seems to be a connection id of some sort (since it changes
>> per connection) - but not the
>> connection id I can grab via the .app file (as described in the
>> section regarding "Connection ID
>> needed for the data store"). I grabbed that connection ID and it is
>> different again from the
>> connectionId returned by the event.
>> I've traced a bit of the code to find out where this was from - but
>> thought perhaps you would just
>> know off hand.
>> Thanks!
>> Todd
>>> Hello Todd,
>>> This document describes the issues in more detail. I would recommend
>>> reading it while looking at the shared presentation code that we already
>>> converted.
>>> http://www.mcs.anl.gov/fl/research/accessgrid/documentation/MigrationGuides/SharedApplicationsMigrationGuide.htm
>>> http://fl-cvs.mcs.anl.gov/viewcvs/viewcvs.cgi/AccessGrid/sharedapps/SharedPresentation/SharedPresentation.py
>>> Susanne
>>> Just trying to migrate my SharedDesktop shared app to AG3 and seem to be
>>> running into a couple of
>>> the issues listed here:
>>> http://www-unix.mcs.anl.gov/fl/research/accessgrid/wiki/moin.cgi/SharedApplicationMigrationIssues
>>> Can someone expand on some of these issues? Specifically:
>>> * Connection id needed for venue data store - should be retreived via
>>> .app file.
>>> I think you are just referring to the venue data store - not the
>>> shared app datastore - correct?
>>> * Reactor imports and wxCallAfter interleave call needed for events to
>>> function.
>>> Figured out this one I think. Added:
>>> try:
>>> from twisted.internet import threadedselectreactor
>>> threadedselectreactor.install()
>>> except:
>>> pass
>>> from twisted.internet import reactor
>>> plus the reactor.interleave(wxCallAfter) call in the panel code
>>> * More restrictive rules on data format for events - do not send tuples
>>> and dictionaries.
>>> Running into this issue right now :-( Was sending a tuple - what
>>> are my choices now??
>>> * Data received from the application service (sharedAppClient.GetData())
>>> may be unicode - convert
>>> data to correct type.
>>> Haven't got the data yet - so can't know if I'll run into this
>>> issue. Can someone expand?
>>> * Get public id of sender by using the new event method; GetSenderId()
>>> Expand?
>>> Thanks!
>>> Todd
