[AG-DEV] AG3 Shared App Migration - EventID
Susanne Lefvert
lefvert at mcs.anl.gov
Tue Aug 29 11:52:16 CDT 2006
Hello Todd,
Which version of the software are you using? The event.GetSenderId()
should return the public id of the sender. We did have a bug in the
software that sounds like the problem you are describing, that
particular bug was fixed in 3.0.2. If you are running earlier
versions of the software, I would recommend updating.
Susanne
On Aug 25, 2006, at 6:01 PM, Todd Zimmerman wrote:
> Hi Susanne,
> Thanks for the help!
> One further clarification. The page you referenced indicates to
> use "the new event method
> event.GetSenderId() to retrieve the public id of a sender" but this
> doesn't seem to be the public Id
> of the sender (from the user's profile).
> Further, it seems to be a connection id of some sort (since it
> changes per connection) - but not the
> connection id I can grab via the .app file (as described in the
> section regarding "Connection ID
> needed for the data store"). I grabbed that connection ID and it
> is different again from the
> connectionId returned by the event.
> I've traced a bit of the code to find out where this was from - but
> thought perhaps you would just
> know off hand.
> Thanks!
> Todd
> Susanne Lefvert wrote:
>> Hello Todd,
>> This document describes the issues in more detail. I would recommend
>> reading it while looking at the shared presentation code that we
>> already
>> converted.
>> http://www.mcs.anl.gov/fl/research/accessgrid/documentation/
>> MigrationGuides/SharedApplicationsMigrationGuide.htm
>> http://fl-cvs.mcs.anl.gov/viewcvs/viewcvs.cgi/AccessGrid/
>> sharedapps/SharedPresentation/SharedPresentation.py
>> Susanne
>> Just trying to migrate my SharedDesktop shared app to AG3 and seem
>> to be
>> running into a couple of
>> the issues listed here:
>> http://www-unix.mcs.anl.gov/fl/research/accessgrid/wiki/moin.cgi/
>> SharedApplicationMigrationIssues
>> Can someone expand on some of these issues? Specifically:
>> * Connection id needed for venue data store - should be retreived via
>> .app file.
>> I think you are just referring to the venue data store - not the
>> shared app datastore - correct?
>> * Reactor imports and wxCallAfter interleave call needed for
>> events to
>> function.
>> Figured out this one I think. Added:
>> try:
>> from twisted.internet import threadedselectreactor
>> threadedselectreactor.install()
>> except:
>> pass
>> from twisted.internet import reactor
>> plus the reactor.interleave(wxCallAfter) call in the panel code
>> * More restrictive rules on data format for events - do not send
>> tuples
>> and dictionaries.
>> Running into this issue right now :-( Was sending a tuple - what
>> are my choices now??
>> * Data received from the application service
>> (sharedAppClient.GetData())
>> may be unicode - convert
>> data to correct type.
>> Haven't got the data yet - so can't know if I'll run into this
>> issue. Can someone expand?
>> * Get public id of sender by using the new event method;
>> GetSenderId()
>> Expand?
>> Thanks!
>> Todd
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20060829/4d0d123b/attachment.htm>
