[AG-DEV] Custom Node Service Enabling/Disabling Problem
Michael Braitmaier
braitmaier at hlrs.de
Mon Aug 14 02:12:26 CDT 2006
In fact I already changed default initialization of the Capability
members, to be set with
values matching their intended type whenever they are set to None.
I added a check for None values and if found, add valid values that work
in the matches()
function.
if self.codec == None:
self.codec=""
if rate == None:
self.rate = 0
However I did not do that for self.type, as I assumed this should be a
value that is always set.
It seems the problem is caused by having a stream Capaility with
rate=0(5th param). Which causes the error.
08/09/2006 11:15:28 AM -1376814176 NodeService AGNodeService.py:699
DEBUG service capabilities: [producer, debug, None, None, None, 1,
consumer, debug, None, None, None, 1]
This should be avoided by the code I added in the constructor, I don't
know why it doesnt work in your case (assuming you use the modifcations
I sent you). Maybe its a better solution to perform the check
directly in the match function:
def matches( self, capability ):
if self.rate == None:
self.rate = 0
self.codec = ""
if self.channels == None:
self.channels = 0
try:
if (str(self.type) != str(capability.type) or
str(self.codec) != str(capability.codec) or
int(self.channels) != int(capability.channels) or
int(self.rate) != int(capability.rate)):
# type mismatch
return 0
except:
print "Exception in capability compare!"
return 0 # Return mismatch as default when error occurs
# capability match
return 1
Michael
Thomas D. Uram schrieb:
> That is an interesting mix of modules identified in the traceback.
> Todd, does
> that make sense to you in the context of the installations you've made on
> that machine? I know that there may be AG3 code in
> site-packages/AccessGrid
> with Doug Kosovic's Fedora packages, so maybe that explains their
> presence.
> It does not, however, explain the _use_ of both of them in one execution.
> The exception is likely due to the rate comparison in this code (the
> first line of
> which appears in the exception):
> because:
> - DebugService creates Capabilities, specifying only the type and role
> attributes
> - the Capability class uses a default of None for the 'rate' attribute
> - Capability.matches casts rate to an int for comparison, which fails
> if 'rate' is None
> I've changed the default value for Capability.rate from None to zero
> in cvs now.
> The problem can be avoided in current services by initializing the
> 'rate' attribute to zero.
> Tom
> On 8/11/06 4:00 AM, Michael Braitmaier wrote:
>> Hi Todd!
>> Looking more into your debug file I can see, that AccessGrid
>> obviously uses AccessGrid code from different versions like in the
>> following extract of the logfile:
>> Traceback (most recent call last):
>> File "/usr/lib/python2.4/site-packages/AccessGrid/AGNodeService.py",
>> line 708, in __SendStreamsToService
>> if c.matches(cap):
>> File
>> "/usr/lib/python2.4/site-packages/AccessGrid3/AccessGrid/Descriptions.py",
>> line 314, in matches
>> TypeError: int() argument must be a string or a number
>> The file AGNodeService.py seems to come from
>> while the file Descriptions.py is coming from
>> python2.4/site-packages/accessGrid3/AccessGrid
>> Possibly there is a mix of AG2.4 and AG3.0 code?
>> Michael
>> Michael Braitmaier schrieb:
>>> Hi Todd!
>>> In fact I think the problem narrows down to the follwing line in the
>>> log:
>>> File
>>> Apprently the two values are not compareable in some way.
>>> I assume you use the modified code which I sent you.
>>> The problem could possibly be introduced by my modifications.
>>> It would be helpful to see what values are contained in
>>> self.type and
>>> capability.type
>>> Possibly one of the variables contain a "None"-value (however this
>>> value got there), which would lead to the given error message.
>>> Refering to Brians assumption on the service not being able to
>>> handle the stream:
>>> In fact at the end the
>>> raise SetStreamException(failedSends)
>>> is just a propagation of the exception in the Capability's match
>>> function.
>>> So I don't think that this caused by the service not being able to
>>> habndle the stream.
>>> Todd:
>>> If you can tell me what values are contained in the variables, I can
>>> help you find the problem and even update my sources eliminating the
>>> bug.
>>> Michael
>>> Todd Zimmerman schrieb:
>>>> Sorry for the spam - but just realized that it looks like this
>>>> issue was identified and a fix was
>>>> made by Michael Braitmaier.
>>>> The problem was the default None values of rate and code in the
>>>> Capabilities class. Michael made
>>>> the default value of codec = "" and rate = 0 - which allows the
>>>> match function to properly check for
>>>> matches. This seems to alleviate the issue - but does it raise
>>>> any other problems??
>>>> Cheers,
>>>> Todd
>>>> Todd Zimmerman wrote:
>>>>> one more time WITH the logfiles... ;-)
>>>>>> Oh... I sent them to ag-dev yesterday...
>>>>>> Here's a resend.
>>>>>> Looks like the relevent section is:
>>>>>> 08/09/2006 11:15:40 AM -1208600896 NodeManagementUIClasses
>>>>>> NodeManagementUIClasses.py:1043 ERROR
>>>>>> Error enabling service
>>>>>> File
>>>>>> "/usr/lib/python2.4/site-packages/AccessGrid3/AccessGrid/NodeManagementUIClasses.py",
>>>>>> line
>>>>>> 1037, in EnableService
>>>>>> self.nodeServiceHandle.SetServiceEnabled(service.uri, 1)
>>>>>> File
>>>>>> line 278, in SetServiceEnabled
>>>>>> self.__SendStreamsToService( serviceUri )
>>>>>> File
>>>>>> line 723, in
>>>>>> SetStreamException: Error updating [producer, debug, None, None,
>>>>>> None, 1, consumer, debug, None,
>>>>>> None, None, 1]
>>>>>> Cheers,
>>>>>> Todd
>>>>>> Thomas D. Uram wrote:
>>>>>>> Any details from logfile?
>>>>>>>>> Also, which platform?
>>>>>>>> Fedora Core 5 running AccessGrid-3.0.2-0.1.20060727cvs
>>>>>>>> Cheers,
>>>>>>>> Todd
>>>>>>>> 08/09/06 11:15:07 -1208117568 Toolkit Config.py:559 DEBUG
>>>>>>>> System hostname of floyd.irmacs.sfu.ca is valid
>>>>>>>> 08/09/06 11:15:07 -1208117568 Toolkit Toolkit.py:111 DEBUG
>>>>>>>> Initializing AG Toolkit version 3.0.2
>>>>>>>> 08/09/06 11:15:07 -1208117568 Toolkit Toolkit.py:112 INFO
>>>>>>>> Command and arguments:
>>>>>>>> ['/data/tz/.AccessGrid3/local_services/DebugService/DebugService.py',
>>>>>>>> '--port', '64864', '--serviceManagerUri',
>>>>>>>> 'http://floyd.irmacs.sfu.ca:11000/ServiceManager', '--token',
>>>>>>>> '8e3a358332f86536e976086dbec2c57f']
>>>>>>>> 08/09/06 11:15:07 -1208117568 VenueClient
>>>>>>>> Preferences.py:180 DEBUG Preferences.LoadPreferences: open file
>>>>>>>> 08/09/06 11:15:07 -1208117568 Toolkit Toolkit.py:161 INFO
>>>>>>>> Logfile Name: DebugService.log
>>>>>>>> 08/09/06 11:15:07 -1208117568 Toolkit Toolkit.py:650 INFO
>>>>>>>> Service init: have profile None
>>>>>>>> 08/09/06 11:15:07 -1208117568 Toolkit Toolkit.py:675 INFO
>>>>>>>> Service Initialization Complete.
>>>>>>>> 08/09/06 11:15:07 -1208117568 Toolkit AGService.py:363
>>>>>>>> INFO Starting Service URI:
>>>>>>>> http://floyd.irmacs.sfu.ca:64864/Services/DebugService.8e3a3583333a6536e9540206adb5e731
>>>>>>>> 08/09/06 11:15:07 -1208117568 Toolkit AGService.py:373
>>>>>>>> DEBUG Registering with service manager;
>>>>>>>> url=http://floyd.irmacs.sfu.ca:11000/ServiceManager
>>>>>>>> 08/09/06 11:15:07 -1225385056 Toolkit DebugService.py:68
>>>>>>>> INFO SetIdentity method called
>>>>>>>> 08/09/06 11:15:12 -1225385056 Toolkit AGService.py:214
>>>>>>>> INFO AGService.SetEnabled : enabled = 0
>>>>>>>> 08/09/06 11:15:12 -1225385056 Toolkit AGService.py:220
>>>>>>>> INFO Stopping service
>>>>>>>> 08/09/06 11:15:12 -1225385056 Toolkit DebugService.py:50
>>>>>>>> INFO Stop method called
>>>>>>>> 08/09/06 11:15:14 -1225385056 Toolkit AGService.py:214
>>>>>>>> INFO AGService.SetEnabled : enabled = 1
>>>>>>>> 08/09/06 11:15:15 -1225385056 Toolkit AGService.py:214
>>>>>>>> 08/09/06 11:15:15 -1225385056 Toolkit AGService.py:220
>>>>>>>> 08/09/06 11:15:15 -1225385056 Toolkit DebugService.py:50
>>>>>>>> 08/09/06 11:15:17 -1225385056 Toolkit AGService.py:214
>>>>>>>> 08/09/06 11:15:23 -1225385056 Toolkit DebugService.py:50
>>>>>>>> 08/09/06 11:15:30 -1225385056 Toolkit AGService.py:214
>>>>>>>> 08/09/06 11:15:30 -1225385056 Toolkit AGService.py:220
>>>>>>>> 08/09/06 11:15:30 -1225385056 Toolkit DebugService.py:50
>>>>>>>> 08/09/06 11:15:38 -1225385056 Toolkit AGService.py:214
>>>>>>>> 08/09/06 11:15:38 -1225385056 Toolkit AGService.py:220
>>>>>>>> 08/09/06 11:15:38 -1225385056 Toolkit DebugService.py:50
>>>>>>>> 08/09/06 11:15:55 -1225385056 Toolkit DebugService.py:50
>>>>>>>> 08/09/06 11:15:58 -1225385056 Toolkit AGService.py:238
>>>>>>>> INFO Shut service down
>>>>>>>> 08/09/06 11:15:58 -1225385056 Toolkit DebugService.py:50
>>>>>>>> 08/09/06 11:15:58 -1208117568 Toolkit AGService.py:238
>>>>>>>> 08/09/06 11:15:58 -1208117568 Toolkit DebugService.py:50
>>>>>>>> 08/09/2006 11:14:55 AM -1208600896 VenueClientController
>>>>>>>> VenueClientController.py:432 DEBUG VenueClientController
>>>>>>>> calling Venue.EnterVenue
>>>>>>>> VenueClient.py:1015 DEBUG EnterVenue;
>>>>>>>> url=https://venueserver2.westgrid.ca:8000/Venues/default
>>>>>>>> 08/09/2006 11:14:55 AM -1208600896 NodeService
>>>>>>>> AGNodeService.py:658 INFO NodeService.GetCapabilities
>>>>>>>> AGNodeService.py:257 INFO NodeService.GetServices
>>>>>>>> 08/09/2006 11:14:55 AM -1225692256 ServiceManager
>>>>>>>> AGServiceManager.py:218 INFO AGServiceManager.GetServices
>>>>>>>> VenueClient.py:1049 DEBUG calling __EnterVenue
>>>>>>>> VenueClient.py:806 DEBUG EnterVenue: Invoke Venue.Enter
>>>>>>>> VenueClient.py:808 DEBUG after Venue.Enter
>>>>>>>> VenueClient.py:810 DEBUG EnterVenue: Invoke Venue.getstate
>>>>>>>> 08/09/2006 11:14:56 AM -1208600896 VenueClient
>>>>>>>> VenueClient.py:812 DEBUG EnterVenue: done Venue.getstate
>>>>>>>> 08/09/2006 11:14:57 AM -1208600896 VenueClient
>>>>>>>> VenueClient.py:835 DEBUG Setting isInVenue flag.
>>>>>>>> VenueClient.py:1051 DEBUG after __EnterVenue
>>>>>>>> VenueClientUI.py:2577 DEBUG bin.VenueClient::EnterVenue: Enter
>>>>>>>> venue with url:
>>>>>>>> VenueClientUI.py:2690 DEBUG Entered venue
>>>>>>>> 08/09/2006 11:14:57 AM -1208600896 VenueClientController
>>>>>>>> VenueClientController.py:434 DEBUG VenueClientController after
>>>>>>>> Venue.EnterVenue
>>>>>>>> 08/09/2006 11:14:57 AM -1225692256 VenueClient
>>>>>>>> VenueClient.py:450 DEBUG Calling Heartbeat, time now: 1155147297
>>>>>>>> VenueClientUI.py:3324 DEBUG ContentListPanel.AddParticipant::
>>>>>>>> AddParticipant Todd Zimmerman (called from
>>>>>>>> ('/usr/lib/python2.4/site-packages/wx-2.6-gtk2-unicode/wx/_core.py',
>>>>>>>> 13535, '<lambda>', 'lambda event: event.callable(*event.args,
>>>>>>>> **event.kw) )'))
>>>>>>>> VenueClient.py:474 DEBUG Next Heartbeat needed within 36s
>>>>>>>> 08/09/2006 11:14:57 AM -1225692256 JabberClient
>>>>>>>> JabberClient.py:33 INFO Connecting to Jabber Server
>>>>>>>> 'jabber.mcs.anl.gov' ...
>>>>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.io io.py:100
>>>>>>>> DEBUG RECV: <?xml version='1.0'?><stream:stream
>>>>>>>> xmlns:stream='http://etherx.jabber.org/streams' id='44DA2621'
>>>>>>>> xmlns='jabber:client' from='jabber.mcs.anl.gov'>
>>>>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.serialize
>>>>>>>> serialize.py:65 DEBUG feed parser initialized
>>>>>>>> serialize.py:72 DEBUG start
>>>>>>>> <{http://etherx.jabber.org/streams}stream> level=0
>>>>>>>> JabberClient.py:168 INFO Registering the user
>>>>>>>> '8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default'
>>>>>>>> in jabber server ...
>>>>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.io io.py:122
>>>>>>>> DEBUG SEND: <iq type="get"><query xmlns="jabber:iq:register"
>>>>>>>> /></iq>
>>>>>>>> 08/09/2006 11:14:57 AM -1225692256 bajjer.io io.py:161
>>>>>>>> DEBUG RECV: <iq type='result'><query
>>>>>>>> xmlns='jabber:iq:register'><password/><password/>
>>>>>>>> <instructions>Choose a username and password to register
>>>>>>>> with this server.</instructions>
>>>>>>>> <name/>
>>>>>>>> <email/>
>>>>>>>> <username/></query></iq>
>>>>>>>> serialize.py:72 DEBUG start <{jabber:client}iq> level=1
>>>>>>>> serialize.py:72 DEBUG start <{jabber:iq:register}query> level=2
>>>>>>>> serialize.py:72 DEBUG start <{jabber:iq:register}password> level=3
>>>>>>>> serialize.py:86 DEBUG end <{jabber:iq:register}password> level=3
>>>>>>>> serialize.py:72 DEBUG start <{jabber:iq:register}instructions>
>>>>>>>> level=3
>>>>>>>> serialize.py:86 DEBUG end <{jabber:iq:register}instructions>
>>>>>>>> level=3
>>>>>>>> serialize.py:72 DEBUG start <{jabber:iq:register}name> level=3
>>>>>>>> serialize.py:86 DEBUG end <{jabber:iq:register}name> level=3
>>>>>>>> serialize.py:72 DEBUG start <{jabber:iq:register}email> level=3
>>>>>>>> serialize.py:86 DEBUG end <{jabber:iq:register}email> level=3
>>>>>>>> serialize.py:72 DEBUG start <{jabber:iq:register}username> level=3
>>>>>>>> serialize.py:86 DEBUG end <{jabber:iq:register}username> level=3
>>>>>>>> serialize.py:86 DEBUG end <{jabber:iq:register}query> level=2
>>>>>>>> serialize.py:86 DEBUG end <{jabber:client}iq> level=1
>>>>>>>> DEBUG SEND: <iq type="set"><query
>>>>>>>> xmlns="jabber:iq:register"><username>8180087163ff65364de2ad59cc6ba1e9</username><password>8180087163ff65364de2ad59cc6ba1e9</password></query></iq>
>>>>>>>> 08/09/2006 11:14:58 AM -1225692256 bajjer.io io.py:161
>>>>>>>> DEBUG RECV: <iq type='result'/>
>>>>>>>> 08/09/2006 11:14:58 AM -1225692256 bajjer.serialize
>>>>>>>> 08/09/2006 11:14:58 AM -1208600896 GroupMsgClient
>>>>>>>> GroupMsgClient.py:112 INFO Connected. Connection ID:
>>>>>>>> 08/09/2006 11:14:58 AM -1208600896 EventClient
>>>>>>>> InsecureVenueEventClient.py:60 INFO BaseVenueEventClient made
>>>>>>>> connection.
>>>>>>>> 08/09/2006 11:14:59 AM -1225692256 JabberClient
>>>>>>>> JabberClient.py:177 INFO Attempting to log in as
>>>>>>>> 8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default ...
>>>>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.io io.py:122
>>>>>>>> xmlns="jabber:iq:auth"><username>8180087163ff65364de2ad59cc6ba1e9</username></query></iq>
>>>>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.io io.py:161
>>>>>>>> xmlns='jabber:iq:auth'><username>8180087163ff65364de2ad59cc6ba1e9</username><digest/><password/><resource/></query></iq>
>>>>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.serialize
>>>>>>>> serialize.py:72 DEBUG start <{jabber:iq:auth}query> level=2
>>>>>>>> serialize.py:72 DEBUG start <{jabber:iq:auth}username> level=3
>>>>>>>> serialize.py:86 DEBUG end <{jabber:iq:auth}username> level=3
>>>>>>>> serialize.py:72 DEBUG start <{jabber:iq:auth}digest> level=3
>>>>>>>> serialize.py:86 DEBUG end <{jabber:iq:auth}digest> level=3
>>>>>>>> serialize.py:72 DEBUG start <{jabber:iq:auth}password> level=3
>>>>>>>> serialize.py:86 DEBUG end <{jabber:iq:auth}password> level=3
>>>>>>>> serialize.py:72 DEBUG start <{jabber:iq:auth}resource> level=3
>>>>>>>> serialize.py:86 DEBUG end <{jabber:iq:auth}resource> level=3
>>>>>>>> serialize.py:86 DEBUG end <{jabber:iq:auth}query> level=2
>>>>>>>> 08/09/2006 11:14:59 AM -1225692256 bajjer.stream
>>>>>>>> stream.py:326 DEBUG Recv: <gov.lbl.dsd.bajjer.stanza.Iq object
>>>>>>>> at 0xb46c2dcc>
>>>>>>>> stream.py:342 DEBUG performing 'digest' authentication
>>>>>>>> xmlns="jabber:iq:auth"><resource>default</resource><username>8180087163ff65364de2ad59cc6ba1e9</username><digest>cf40bb3969d2778217e87b01c0948d0cf96ec019</digest></query></iq>
>>>>>>>> DEBUG RECV: <iq type='result' id='pthsock_client_auth_ID'/>
>>>>>>>> stream.py:351 DEBUG Authorization succeeded
>>>>>>>> DEBUG SEND: <iq from="8180087163ff65364de2ad59cc6ba1e9"
>>>>>>>> type="get"><query xmlns="jabber:iq:roster" /></iq>
>>>>>>>> DEBUG RECV: <iq
>>>>>>>> from='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default'
>>>>>>>> type='result'><query xmlns='jabber:iq:roster'/></iq>
>>>>>>>> serialize.py:72 DEBUG start <{jabber:iq:roster}query> level=2
>>>>>>>> serialize.py:86 DEBUG end <{jabber:iq:roster}query> level=2
>>>>>>>> DEBUG SEND: <presence />
>>>>>>>> JabberClient.py:73 DEBUG Sending the presence to
>>>>>>>> 'Main-Lobby(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd
>>>>>>>> Zimmerman' of type 'available'...
>>>>>>>> to="Main-Lobby(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd
>>>>>>>> Zimmerman" type="available"><x /></presence>
>>>>>>>> 08/09/2006 11:14:59 AM -1225692256 VenueClient
>>>>>>>> VenueClient.py:959 INFO VenueClient.StartBeacon: Address
>>>>>>>> 233.59.192.88/49482
>>>>>>>> 08/09/2006 11:14:59 AM -1225692256 RTPBeacon
>>>>>>>> RTPBeacon.py:278 DEBUG Called Start.
>>>>>>>> VenueClient.py:1231 INFO In UpdateStream: transport=unicast
>>>>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.io io.py:161
>>>>>>>> DEBUG RECV: <message from='jabber.mcs.anl.gov'
>>>>>>>> to='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov'>
>>>>>>>> <subject>Welcome!</subject>
>>>>>>>> <body>Welcome to the Access Grid Jabber server @
>>>>>>>> jabber.mcs.anl.gov -- we hope you enjoy this service! For
>>>>>>>> information about how to use Jabber, visit the Jabber
>>>>>>>> User's Guide at http://jabbermanual.jabberstudio.org/</body>
>>>>>>>> <x xmlns='jabber:x:delay'
>>>>>>>> from='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov'
>>>>>>>> stamp='20060809T18:14:57'>Offline Storage</x></message>
>>>>>>>> 08/09/2006 11:14:59 AM -1345344608 bajjer.serialize
>>>>>>>> serialize.py:72 DEBUG start <{jabber:client}message> level=1
>>>>>>>> serialize.py:72 DEBUG start <{jabber:client}subject> level=2
>>>>>>>> serialize.py:86 DEBUG end <{jabber:client}subject> level=2
>>>>>>>> serialize.py:72 DEBUG start <{jabber:client}body> level=2
>>>>>>>> serialize.py:86 DEBUG end <{jabber:client}body> level=2
>>>>>>>> serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
>>>>>>>> serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
>>>>>>>> serialize.py:86 DEBUG end <{jabber:client}message> level=1
>>>>>>>> 08/09/2006 11:14:59 AM -1345344608 JabberClient
>>>>>>>> JabberClient.py:133 DEBUG jabber.mcs.anl.go: Welcome to the
>>>>>>>> Access Grid Jabber server @ jabber.mcs.anl.gov -- we hope you
>>>>>>>> enjoy this service! For information about how to use Jabber,
>>>>>>>> visit the Jabber User's Guide at
>>>>>>>> VenueClient.py:1260 DEBUG Got location from bridge: unicast
>>>>>>>> milton.mcs.anl.gov 53768
>>>>>>>> DEBUG RECV: <presence
>>>>>>>> to='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default'
>>>>>>>> from='main-lobby(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd
>>>>>>>> Zimmerman'><x/><x
>>>>>>>> xmlns='http://jabber.org/protocol/muc#user'><item
>>>>>>>> affiliation='none' role='participant'/></x></presence>
>>>>>>>> serialize.py:72 DEBUG start <{jabber:client}presence> level=1
>>>>>>>> serialize.py:72 DEBUG start <{jabber:client}x> level=2
>>>>>>>> serialize.py:86 DEBUG end <{jabber:client}x> level=2
>>>>>>>> <{http://jabber.org/protocol/muc#user}x> level=2
>>>>>>>> <{http://jabber.org/protocol/muc#user}item> level=3
>>>>>>>> serialize.py:86 DEBUG end <{jabber:client}presence> level=1
>>>>>>>> JabberClient.py:145 DEBUG
>>>>>>>> Zimmerman is available (None / None)
>>>>>>>> 08/09/2006 11:14:59 AM -1345344608 VenueClient
>>>>>>>> VenueClientUI.py:2299 DEBUG add user: Todd Zimmerman
>>>>>>>> DEBUG RECV: <message type='groupchat'
>>>>>>>> from='main-lobby(venueserver2.westgrid.ca)@conference.mcs.anl.gov'><body>main-lobby(venueserver2.westgrid.ca)</body></message>
>>>>>>>> main-lobby(venueserver2.westgrid.ca)@conference.mcs.anl.go:
>>>>>>>> from='main-lobby(venueserver2.westgrid.ca)@conference.mcs.anl.gov'><body>This
>>>>>>>> room supports the MUC protocol.</body></message>
>>>>>>>> milton.mcs.anl.gov 52884
>>>>>>>> to='8180087163ff65364de2ad59cc6ba1e9 at jabber.mcs.anl.gov/default'><body>Todd
>>>>>>>> Zimmerman has joined this session</body></message>
>>>>>>>> This room supports the MUC protocol.
>>>>>>>> Todd Zimmerman has joined this session
>>>>>>>> milton.mcs.anl.gov 52844
>>>>>>>> RTPBeacon.py:296 DEBUG Called Stop.
>>>>>>>> VenueClient.py:951 INFO Beacon being reconfigured, stopping
>>>>>>>> running beacon
>>>>>>>> milton.mcs.anl.gov/52844
>>>>>>>> VenueClient.py:1190 DEBUG UpdateNodeService: Method
>>>>>>>> UpdateNodeService called
>>>>>>>> VenueClient.py:1195 DEBUG Setting node service streams
>>>>>>>> 08/09/2006 11:14:59 AM -1225692256 NodeService
>>>>>>>> AGNodeService.py:328 INFO NodeService.SetStreams
>>>>>>>> 08/09/2006 11:14:59 AM -1387304032 ServiceManager
>>>>>>>> 08/09/2006 11:15:00 AM -1225692256 NodeService
>>>>>>>> AGNodeService.py:695 INFO NodeService.__SendStreamsToService
>>>>>>>> 08/09/2006 11:15:00 AM -1366324320 RTPBeacon
>>>>>>>> RTPBeacon.py:289 INFO RTPBeacon.UpdateThread exiting
>>>>>>>> AGNodeService.py:699 DEBUG service capabilities: [consumer,
>>>>>>>> audio, 8e3a358333096536dec30af9596ae5ae, L16, 16000, 1,
>>>>>>>> consumer, audio, 8e3a358333096536dec30af9596ae5ae, L16, 8000,
>>>>>>>> 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae, L8,
>>>>>>>> 16000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae,
>>>>>>>> L8, 8000, 1, consumer, audio, 8e3a358333096536dec30af9596ae5ae,
>>>>>>>> PCMU, 16000, 1, consumer, audio,
>>>>>>>> 8e3a358333096536dec30af9596ae5ae, PCMU, 8000, 1, consumer,
>>>>>>>> audio, 8e3a358333096536dec30af9596ae5ae, GSM, 16000, 1,
>>>>>>>> consumer, audio, 8e3a358333096536dec30af9596ae5ae, GSM, 8000,
>>>>>>>> 1, producer, audio, 8e3a358333096536dec30af9596ae5ae, L16,
>>>>>>>> 16000, 1]
>>>>>>>> AGNodeService.py:713 INFO Sending stream (type=[consumer,
>>>>>>>> audio, 8180087163ff629be0bebd48a1912f0f, L16, 16000, 1,
>>>>>>>> consumer, audio, 8180087163ff629be0bebd48a1912f0f, L16, 8000,
>>>>>>>> 1, consumer, audio, 8180087163ff629be0bebd48a1912f0f, L8,
>>>>>>>> 16000, 1, consumer, audio, 8180087163ff629be0bebd48a1912f0f,
>>>>>>>> L8, 8000, 1, consumer, audio, 8180087163ff629be0bebd48a1912f0f,
>>>>>>>> 8180087163ff629be0bebd48a1912f0f, PCMU, 8000, 1, consumer,
>>>>>>>> audio, 8180087163ff629be0bebd48a1912f0f, GSM, 16000, 1,
>>>>>>>> consumer, audio, 8180087163ff629be0bebd48a1912f0f, GSM, 8000,
>>>>>>>> 1]) to service:
>>>>>>>> http://floyd.irmacs.sfu.ca:56488/Services/AudioService.8e3a358333096536decfdc29e8e7216d
>>>>>>>> video, 8e3a358333036536de76e51f5b703c18, H261, 90000, 1,
>>>>>>>> producer, video, 8e3a358333036536de76e51f5b703c18, H261, 90000, 1]
>>>>>>>> video, 8180087163ff629be0bbbd489dcbd809, H261, 90000, 1]) to
>>>>>>>> service:
>>>>>>>> http://floyd.irmacs.sfu.ca:62272/Services/VideoService.8e3a358333036536de95b64fe81b7c08
>>>>>>>> 08/09/2006 11:15:00 AM -1225692256 VenueClient
>>>>>>>> VenueClient.py:914 DEBUG Updating client profile cache.
>>>>>>>> 08/09/2006 11:15:00 AM -1208600896 VenueClient
>>>>>>>> VenueClientUI.py:1291 DEBUG VenueClientFrame.ManageNodeCB: open
>>>>>>>> node management
>>>>>>>> VenueClientUI.py:1292 DEBUG nodeservice url:
>>>>>>>> <AccessGrid.AGNodeService.AGNodeService instance at 0xb6f3518c>
>>>>>>>> 08/09/2006 11:15:00 AM -1208600896 NodeService
>>>>>>>> AGNodeService.py:248 INFO NodeService.GetServiceManagers
>>>>>>>> 08/09/2006 11:15:00 AM -1225692256 ServiceManager
>>>>>>>> 08/09/2006 11:15:07 AM -1225692256 ServiceManager
>>>>>>>> AGServiceManager.py:102 INFO AGServiceManager.AddService
>>>>>>>> AGServiceManager.py:339 INFO Installed service version: 1.1,
>>>>>>>> package version: 1.1
>>>>>>>> AGServiceManager.py:374 DEBUG Executing service DebugService
>>>>>>>> AGServiceManager.py:406 INFO Running Service; options:
>>>>>>>> '--port', 64864, '--serviceManagerUri',
>>>>>>>> AGServiceManager.py:418 INFO Service registered:
>>>>>>>> 08/09/2006 11:15:07 AM -1208600896 NodeManagementUIClasses
>>>>>>>> NodeManagementUIClasses.py:1000 INFO No resources for service
>>>>>>>> 08/09/2006 11:15:07 AM -1208600896 VenueClient
>>>>>>>> VenueClientUI.py:1933 INFO OnNodeActivity: got action:
>>>>>>>> add_service
>>>>>>>> 08/09/2006 11:15:07 AM -1208600896 NodeService
>>>>>>>> 08/09/2006 11:15:12 AM -1208600896 NodeService
>>>>>>>> AGNodeService.py:275 INFO NodeService.SetServiceEnabled
>>>>>>>> 08/09/2006 11:15:12 AM -1225692256 ServiceManager
>>>>>>>> 08/09/2006 11:15:14 AM -1208600896 NodeManagementUIClasses
>>>>>>>> NodeManagementUIClasses.py:1036 DEBUG
>>>>>>>> NodeManagementClientFrame.EnableService: Enabling Service:
>>>>>>>> DebugService
>>>>>>>> 08/09/2006 11:15:14 AM -1208600896 NodeService
>>>>>>>> AGNodeService.py:699 DEBUG service capabilities: [producer,
>>>>>>>> debug, None, None, None, 1, consumer, debug, None, None, None, 1]
>>>>>>>> 08/09/2006 11:15:14 AM -1225692256 ServiceManager
>>>>>>>> 08/09/2006 11:15:15 AM -1208600896 NodeService
>>>>>>>> 08/09/2006 11:15:15 AM -1225692256 ServiceManager
>>>>>>>> 08/09/2006 11:15:16 AM -1208600896 NodeManagementUIClasses
>>>>>>>> DebugService
>>>>>>>> 08/09/2006 11:15:17 AM -1208600896 NodeService
>>>>>>>> 08/09/2006 11:15:17 AM -1225692256 ServiceManager
>>>>>>>> 08/09/2006 11:15:23 AM -1208600896 VenueClient
>>>>>>>> VenueClient.py:1132 INFO ExitVenue
>>>>>>>> VenueClient.py:1173 INFO ExitVenue: Stopping node services
>>>>>>>> 08/09/2006 11:15:23 AM -1208600896 NodeService
>>>>>>>> AGNodeService.py:301 INFO NodeService.StopServices
>>>>>>>> 08/09/2006 11:15:23 AM -1225692256 ServiceManager
>>>>>>>> AGServiceManager.py:225 INFO AGServiceManager.StopServices
>>>>>>>> 08/09/2006 11:15:24 AM -1208600896 NodeService
>>>>>>>> 08/09/2006 11:15:24 AM -1225692256 ServiceManager
>>>>>>>> 16000, 1]
>>>>>>>> 08/09/2006 11:15:25 AM -1208600896 VenueClient
>>>>>>>> VenueClient.py:1103 DEBUG ExitVenue: Stop event client obj
>>>>>>>> VenueClient.py:1105 DEBUG ExitVenue: Remove event client reference
>>>>>>>> VenueClient.py:1110 INFO ExitVenue: Stopping text client
>>>>>>>> 08/09/2006 11:15:25 AM -1208600896 JabberClient
>>>>>>>> Zimmerman' of type 'unavailable'...
>>>>>>>> 08/09/2006 11:15:25 AM -1208600896 bajjer.io io.py:122
>>>>>>>> Zimmerman" type="unavailable"><x /></presence>
>>>>>>>> 08/09/2006 11:15:25 AM -1208600896 RTPBeacon
>>>>>>>> 08/09/2006 11:15:25 AM -1208600896 VenueClientController
>>>>>>>> url=https://venueserver2.westgrid.ca:8000/Venues/8e3a35534ae01a166229939b5aed6d47
>>>>>>>> 08/09/2006 11:15:25 AM -1208600896 NodeService
>>>>>>>> 08/09/2006 11:15:25 AM -1334854752 ServiceManager
>>>>>>>> 08/09/2006 11:15:25 AM -1345344608 bajjer.io io.py:161
>>>>>>>> type='unavailable'
>>>>>>>> Zimmerman'><x/><x
>>>>>>>> affiliation='none' role='none'/></x></presence>
>>>>>>>> 08/09/2006 11:15:25 AM -1345344608 bajjer.serialize
>>>>>>>> 08/09/2006 11:15:25 AM -1345344608 JabberClient
>>>>>>>> JabberClient.py:148 DEBUG
>>>>>>>> Zimmerman is unavailable (None / None)
>>>>>>>> 08/09/2006 11:15:25 AM -1345344608 VenueClient
>>>>>>>> VenueClientUI.py:2313 DEBUG remove user: Todd Zimmerman
>>>>>>>> 08/09/2006 11:15:25 AM -1376814176 RTPBeacon
>>>>>>>> 08/09/2006 11:15:26 AM -1208600896 VenueClient
>>>>>>>> venue with url:
>>>>>>>> 08/09/2006 11:15:26 AM -1208600896 VenueClientController
>>>>>>>> Venue.EnterVenue
>>>>>>>> 08/09/2006 11:15:26 AM -1376814176 VenueClient
>>>>>>>> VenueClient.py:450 DEBUG Calling Heartbeat, time now: 1155147326
>>>>>>>> VenueClientUI.py:3340 DEBUG ContentListPanel.RemoveParticipant:
>>>>>>>> Remove participant
>>>>>>>> **event.kw) )'))
>>>>>>>> 08/09/2006 11:15:27 AM -1376814176 VenueClient
>>>>>>>> 08/09/2006 11:15:27 AM -1376814176 JabberClient
>>>>>>>> 'AG-Tech-Room(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd
>>>>>>>> 08/09/2006 11:15:27 AM -1376814176 bajjer.io io.py:122
>>>>>>>> to="AG-Tech-Room(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd
>>>>>>>> running beacon
>>>>>>>> 08/09/2006 11:15:27 AM -1376814176 RTPBeacon
>>>>>>>> 233.59.192.114/63534
>>>>>>>> 08/09/2006 11:15:27 AM -1345344608 bajjer.io io.py:161
>>>>>>>> from='ag-tech-room(venueserver2.westgrid.ca)@conference.mcs.anl.gov/Todd
>>>>>>>> Zimmerman'><x/><x
>>>>>>>> 08/09/2006 11:15:27 AM -1345344608 bajjer.serialize
>>>>>>>> 08/09/2006 11:15:27 AM -1345344608 JabberClient
>>>>>>>> 08/09/2006 11:15:27 AM -1345344608 VenueClient
>>>>>>>> from='ag-tech-room(venueserver2.westgrid.ca)@conference.mcs.anl.gov'><body>ag-tech-room(venueserver2.westgrid.ca)</body></message>
>>>>>>>> ag-tech-room(venueserver2.westgrid.ca)@conference.mcs.anl.go:
>>>>>>>> from='ag-tech-room(venueserver2.westgrid.ca)@conference.mcs.anl.gov'><body>This
>>>>>>>> milton.mcs.anl.gov 53368
>>>>>>>> 08/09/2006 11:15:27 AM -1208600896 EventClient
>>>>>>>> InsecureVenueEventClient.py:77 INFO BaseVenueEventClient lost
>>>>>>>> connection.
>>>>>>>> milton.mcs.anl.gov 53100
>>>>>>>> milton.mcs.anl.gov 53004
>>>>>>>> 08/09/2006 11:15:27 AM -1208600896 GroupMsgClient
>>>>>>>> 8180087163ff6536598e606758d7f94f
>>>>>>>> connection.
>>>>>>>> 08/09/2006 11:15:28 AM -1376814176 VenueClient
>>>>>>>> milton.mcs.anl.gov 52582
>>>>>>>> 08/09/2006 11:15:28 AM -1376814176 RTPBeacon
>>>>>>>> running beacon
>>>>>>>> milton.mcs.anl.gov/52582
>>>>>>>> 08/09/2006 11:15:28 AM -1398592608 ServiceManager
>>>>>>>> 16000, 1]
>>>>>>>> audio, 8180087163ff629be074b224aad547b3, L16, 16000, 1,
>>>>>>>> consumer, audio, 8180087163ff629be074b224aad547b3, L16, 8000,
>>>>>>>> 1, consumer, audio, 8180087163ff629be074b224aad547b3, L8,
>>>>>>>> 16000, 1, consumer, audio, 8180087163ff629be074b224aad547b3,
>>>>>>>> L8, 8000, 1, consumer, audio, 8180087163ff629be074b224aad547b3,
>>>>>>>> 8180087163ff629be074b224aad547b3, PCMU, 8000, 1, consumer,
>>>>>>>> audio, 8180087163ff629be074b224aad547b3, GSM, 16000, 1,
>>>>>>>> consumer, audio, 8180087163ff629be074b224aad547b3, GSM, 8000,
>>>>>>>> 1]) to service:
>>>>>>>> AGNodeService.py:718 ERROR Exception in
>>>>>>>> AGNodeService.__SendStreamsToService.
>>>>>>>> File
>>>>>>>> if c.matches(cap):
>>>>>>>> File
>>>>>>>> VenueClient.py:1199 ERROR Error setting streams
>>>>>>>> File
>>>>>>>> "/usr/lib/python2.4/site-packages/AccessGrid3/AccessGrid/VenueClient.py",
>>>>>>>> line 1197, in UpdateNodeService
>>>>>>>> self.nodeService.SetStreams( self.streamDescList )
>>>>>>>> File
>>>>>>>> line 340, in SetStreams
>>>>>>>> self.__SendStreamsToService( service.uri )
>>>>>>>> File
>>>>>>>> line 723, in __SendStreamsToService
>>>>>>>> 08/09/2006 11:15:28 AM -1225692256 RTPBeacon
>>>>>>>> 08/09/2006 11:15:30 AM -1208600896 NodeService
>>>>>>>> 08/09/2006 11:15:30 AM -1225692256 ServiceManager
>>>>>>>> 08/09/2006 11:15:35 AM -1208600896 NodeManagementUIClasses
>>>>>>>> DebugService
>>>>>>>> 08/09/2006 11:15:35 AM -1208600896 NodeService
>>>>>>>> File
>>>>>>>> if c.matches(cap):
>>>>>>>> File
>>>>>>>> AGNodeService.py:282 ERROR
>>>>>>>> File
>>>>>>>> File
>>>>>>>> NodeManagementUIClasses.py:1043 ERROR Error enabling service
>>>>>>>> File
>>>>>>>> line 1037, in EnableService
>>>>>>>> File
>>>>>>>> File
>>>>>>>> 08/09/2006 11:15:38 AM -1208600896 NodeService
>>>>>>>> 08/09/2006 11:15:38 AM -1225692256 ServiceManager
>>>>>>>> DebugService
>>>>>>>> 08/09/2006 11:15:40 AM -1208600896 NodeService
>>>>>>>> File
>>>>>>>> if c.matches(cap):
>>>>>>>> File
>>>>>>>> File
>>>>>>>> File
>>>>>>>> File
>>>>>>>> File
>>>>>>>> File
>>>>>>>> 08/09/2006 11:15:54 AM -1208600896 VenueClient
>>>>>>>> VenueClientUI.py:2200 INFO --------- END VenueClient
>>>>>>>> 08/09/2006 11:15:54 AM -1208600896 NodeService
>>>>>>>> 08/09/2006 11:15:54 AM -1225692256 ServiceManager
>>>>>>>> 08/09/2006 11:15:55 AM -1208600896 NodeService
>>>>>>>> 08/09/2006 11:15:55 AM -1225692256 ServiceManager
>>>>>>>> 16000, 1]
>>>>>>>> 08/09/2006 11:15:56 AM -1208600896 NodeService
>>>>>>>> 08/09/2006 11:15:56 AM -1208600896 VenueClient
>>>>>>>> 08/09/2006 11:15:56 AM -1208600896 JabberClient
>>>>>>>> 08/09/2006 11:15:56 AM -1208600896 bajjer.io io.py:122
>>>>>>>> 08/09/2006 11:15:56 AM -1208600896 RTPBeacon
>>>>>>>> 08/09/2006 11:15:56 AM -1208600896 ServiceManager
>>>>>>>> AGServiceManager.py:70 INFO AGServiceManager.Shutdown
>>>>>>>> AGServiceManager.py:71 INFO Remove services
>>>>>>>> AGServiceManager.py:208 INFO AGServiceManager.RemoveServices
>>>>>>>> AGServiceManager.py:162 INFO AGServiceManager.RemoveService
>>>>>>>> 08/09/2006 11:15:56 AM -1345344608 bajjer.io io.py:161
>>>>>>>> type='unavailable'
>>>>>>>> Zimmerman'><x/><x
>>>>>>>> 08/09/2006 11:15:56 AM -1345344608 bajjer.serialize
>>>>>>>> 08/09/2006 11:15:56 AM -1366324320 RTPBeacon
>>>>>>>> 08/09/2006 11:15:56 AM -1345344608 JabberClient
>>>>>>>> 08/09/2006 11:15:56 AM -1345344608 VenueClient
>>>>>>>> 08/09/2006 11:15:58 AM -1208600896 ServiceManager
>>>>>>>> 08/09/2006 11:16:00 AM -1208600896 ServiceManager
>>>>>>>> 08/09/2006 11:16:02 AM -1208600896 ServiceManager
>>>>>>>> AGServiceManager.py:73 INFO Stop network interface
>>>>>>>> 08/09/2006 11:16:02 AM -1208600896 RTPBeacon
Dipl.-Inf. Michael Braitmaier
HLRS - Visualization / Video Conferencing
University of Stuttgart
Germany
Phone: ++49 711 685 65996
Fax : ++49 711 682 357
Website: http://www.hlrs.de/people/braitmaier/
