[AG-DEV] Custom Node Service Enabling/Disabling Problem
Todd Zimmerman
toddz at sfu.ca
Wed Aug 9 13:48:35 CDT 2006
Sorry - forgot to attach the relevent log files.
Todd
Todd Zimmerman wrote:
> I'm having an issue with enabling/disabling a custom node service. I have since tried the same
> thing with the DebugService and it appears the same problem exists.
> Here is the behaviour:
> Start AG3 and connect to venue
> Bring up Node Configuration and add DebugService
> Disable/Enable service (works fine).
> Change Venues
> Disable service OK. Enable service fails. (in fact I think there is a failure when changing venues
> also... but didn't fully look at the logs.)
> Further, this (bug?) is also true when:
> Start AG3 - Add DebugService
> Connect to VenueServer
> Disable Debugservice (works fine)
> Enable Service fails.
> Is this a bug - shall I report it? Is it a problem with using the 2.4 Debug Service in AG3?
> Any help appreciated.
> Thanks!
> Todd
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20060809/2f60695f/attachment.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20060809/2f60695f/attachment-0001.bin>
