[AG-DEV] node services connecting via a unicast bridge?
Thomas D. Uram
turam at mcs.anl.gov
Wed Sep 21 12:18:01 CDT 2005
This should be working. When the client enters, the agdevicecontrol stream
should be allocated, and the BridgeServer should create a bridge for it,
advertising it in the agdevicecontrol StreamDescription. I assume this is
working correctly, and the devicecontrol service gets the bridge address.
The underlying QuickBridge is noisy to stdout; you could try watching that
output to see if it acknowledges the client. If that's in order, I'd try
watching traffic out of the bridge machine (using ethereal) as a start.
Tom
On 9/20/05 8:11 PM, Darran Edmundson wrote:
> Hi All,
> We've encountered a problem with AGDeviceControl when run on a node
> connecting
> via a unicast bridge. If you look at our node service script:
> http://trac.agcentral.org/AGDeviceControl/file/trunk/
> agdevicecontrol/AGTk/DeviceControlService.py
> you'll see that we define an agdevicecontrol producer stream. This
> gives us a multicast
> group and port over which we do AGDeviceControl heartbeat and
> discovery. This works
> beautifully for multicast-connected nodes. However, nodes connected
> via a unicast
> bridge are not receiving heartbeats. We have verified this with an
> Ethereal packet
> dump. Namely, vic and rat streams are coming through but not our
> custom agdevicecontrol
> traffic. Surely the bridge routes all streams, no?
> Cheers,
> Darran.
