[AG-DEV] AccessGrid.interfaces
Susanne Lefvert
lefvert at mcs.anl.gov
Wed May 25 15:49:40 CDT 2005
Hello Mike,
Since you are looking at current CVS, the interface classes are specific
to the new soap implementation we will use in the 3.0 release based on
ZSI. CVS is currently going through major modifications so I would suggest
you to view the r_2_3_final tag of CVS. That is code for the 2.3 release
of the software which includes the VenueIW interface.
http://fl-cvs.mcs.anl.gov/viewcvs/viewcvs.cgi/AccessGrid/?only_with_tag=r_2_3_final
Look in AccessGrid/Venue.py
Hope this helps,
Susanne
On Wed, 25 May 2005, Michael Miller wrote:
> Often I see something like the following:
> from AccessGrid.interfaces.Venue_client import VenueIW
> so I go looking in the AccessGrid folder for a .py file called
> 'interfaces', but I can't find it. The lower-case 'i' leads me to
> believe there's some other mechanism going on here. Can someone clue me
> in... ? I'm specifically looking for the implementation of VenueIW, but
> I'd like to understand what the 'interfaces' thing is...
> Thanx,
> Michael Miller
> System Engineer
> Video Technology Services
> Persistent Infrastructure Directorate
> National Center for Supercomputing Applications
> University of Illinois - UC
> 217-649-0747
> "If you're clear in your vision and trust the people in your team with clear objectives, they will invariably do their best to achieve everything desired, and usually deliver everything you could have hoped for and even more." -Paul Debevec
