[AG-DEV] Error 2.4 client connecting to 2.3 server
Susanne Lefvert
lefvert at mcs.anl.gov
Mon Aug 29 09:17:10 CDT 2005
Mike,
Do you get the same error if you uninstall the toolkit first? If you do,
could you please send us your log files found in Document and
Settings/<user>/Application Data/AccessGrid/Logs
Susanne
On Mon, 29 Aug 2005, Michael Miller wrote:
> I installed AGtk2.4 without removing AGtk2.3 on my client machine. It's
> WinXP on an IBM Thinkpad. So perhaps that was a mistake, but I like
> messing with things like that... ;-)
> Anyways, I now am seeing the reconnect over and over behavior that I
> had seen previous to 2.3. The client continuously tries to reconnect
> and the venue gets populated with hundreds of instances of my client
> name. Here's the traceback:
> C:\>"c:\Program Files\AGtk-2.4\bin\VenueClient.py" --personalNode
> *** Method NodeService:SetStreams exception ****************************
> Traceback (most recent call last):
> File "C:\Python23\Lib\site-packages\SOAPpy\Server.py", line 408, in
> do_POST
> fr = apply(f, ordered_args, named_args)
> TypeError: SetStreams() got an unexpected keyword argument 'item'
> <Fault SOAP-ENV:Server: Method Failed: NodeService:SetStreams>
> Would this be caused by my installation procedure or is there something
> more going on here?
> MYK
> Thanx,
> Michael Miller
> System Engineer
> Video Technology Services
> Persistent Infrastructure Directorate
> National Center for Supercomputing Applications
> University of Illinois - UC
> 217-649-0747
> "If you're clear in your vision and trust the people in your team with clear objectives, they will invariably do their best to achieve everything desired, and usually deliver everything you could have hoped for and even more." -Paul Debevec
