AG Dev Certificate Approved
Robert Olson
olson at mcs.anl.gov
Fri Sep 17 15:58:42 CDT 2004
That typically means the clock on either your machine or the server is not
correct.
--bob
At 03:57 PM 9/17/2004, Carsten Poulsen wrote:
>When I try to use the certificate and connect to the proxy it says remote
>certificate is not yet valid. What is the problem?
>-Carsten
>-----Original Message-----
>From: root at fl-caserver.mcs.anl.gov [mailto:root at fl-caserver.mcs.anl.gov]
>Sent: 17. september 2004 13:04
>To: cp at WPI.EDU
>Subject: AG Dev Certificate Approved
>Your certificate request to the AG Developers CA has been approved and your
>certificate is ready. You can retrieve this certificate automatically by
>running the Venues Client and picking View Pending requests from the
>Preferences->Certificate Manager Menu item. The DN for this request was:
>O=Access Grid, OU=agdev-ca.mcs.anl.gov, OU=wpi.edu, CN=Carsten Poulsen
