AG 2.3 Packaging
Thomas D. Uram
turam at mcs.anl.gov
Mon Sep 13 08:38:27 CDT 2004
Hi Doug:
SOAPpy and pyGlobus should be the same in the 2.3beta2 and 2.3 source
tarballs. I'll look today at the additional output that Chris
mentioned, and see if I can reduce/eliminate it.
Tom
Douglas Kosovic wrote:
> Could someone make available a tar file with the modified SOAPpy 0.11.4
> and also the pyGlobus that should be used? I'm not confident enough to
> know which version should be used.
> I used the version of SOAPpy from the Gentoo AGTk 2.3 source tarball and
> VenueClient outputs the same diagnostic info, regardless of if the
> '--debug' switch is specified or not. Using the SOAPpy from 2.3 beta 2,
> the '--debug' switch with VenueClient seems to output more debugging info.
> I'm going to delay the release of the Fedora version till Tuesday. I'm
> wondering if the pyGlobus error messages below will be silenced soon? If
> so, I might wait till they are silenced.
