venue clients and observers
Robert Olson
olson at mcs.anl.gov
Mon Mar 29 17:03:03 CST 2004
Not sure; I need to see what the existing handle error stuff does, this
feels a little different. (what it takes is an exxception object, and
returns a boolean that specifies whether or not the call shoudl be retried).
--bob
At 05:01 PM 3/29/2004, Thomas D. Uram wrote:
>There's a HandleError method in the observer. If you define an error
>class, you can trigger the VenueClientUI to handle it appropriately.
>Does that satisfy what your after?
>Tom
>Robert Olson wrote:
>>So I'm looking at adding the functionality where an failed invocation
>>through a VenueIW will trigger a callback to the app if it's an
>>exception that can be handled by some certmgr interaction with the user.
>>The notification ends up happening in a fault handler method in the
>>VenueClient object (that was registered as the fault handler on the
>>VenueIW). I need to get the invocation thru to the venue client UI and
>>eventually to the gui cert mgmt stuff.
>>At first blush, it seems I should be able to use an observer on the venue
>>client. It looks like for this, I'd need to add another method to
>>VenueObserver and its subclasses - does that fit with your design model?
>>--bob
