venue clients and observers
Thomas D. Uram
turam at mcs.anl.gov
Mon Mar 29 17:01:47 CST 2004
There's a HandleError method in the observer. If you define an error
class, you can trigger the VenueClientUI to handle it appropriately.
Does that satisfy what your after?
Tom
Robert Olson wrote:
> So I'm looking at adding the functionality where an failed invocation
> through a VenueIW will trigger a callback to the app if it's an
> exception that can be handled by some certmgr interaction with the user.
> The notification ends up happening in a fault handler method in the
> VenueClient object (that was registered as the fault handler on the
> VenueIW). I need to get the invocation thru to the venue client UI and
> eventually to the gui cert mgmt stuff.
> At first blush, it seems I should be able to use an observer on the
> venue client. It looks like for this, I'd need to add another method
> to VenueObserver and its subclasses - does that fit with your design
> model?
> --bob
