Fault handling redirects in SOAPpy
Thomas D. Uram
turam at mcs.anl.gov
Mon Mar 8 16:03:40 CST 2004
I like this, too. It means that we don't have to smatter our code with
checking for a valid proxy cert, it'll just happen automatically with
each (failed) soap call. I think we really need to be able to isolate
it to authentication-related exceptions, though, since we don't want to
retry the call in the face of unrelated failures.
Ivan R. Judson wrote:
>Looks cool; but I'm missing the motivation for it? Is something broken
>without this?
>--Ivan
>>-----Original Message-----
>>From: owner-ag-dev at mcs.anl.gov
>>[mailto:owner-ag-dev at mcs.anl.gov] On Behalf Of Robert Olson
>>Sent: Monday, March 08, 2004 2:55 PM
>>To: ag-dev at mcs.anl.gov
>>Subject: Fault handling redirects in SOAPpy
>>Try this on for size. In SOAPpy/CLient.py:
>>--- Client.py~ 2004-02-17 22:05:59.000000000 -0600
>>+++ Client.py 2004-03-08 14:45:21.000000000 -0600
>>@@ -339,11 +339,46 @@
>> header = hd, methodattrs = ma, encoding = self.encoding,
>> config = self.config, noroot = self.noroot)
>>- r, self.namespace = self.transport.call(self.proxy,
>>m, ns, sa,
>>- encoding =
>>self.encoding,
>>- http_proxy =
>>self.http_proxy,
>>- config = self.config)
>>+ call_retry = 0
>>+ try:
>>+ r, self.namespace =
>>self.transport.call(self.proxy, m, ns, sa,
>>+ encoding
>>= self.encoding,
>>+ http_proxy =
>>self.http_proxy,
>>+ config =
>>+ self.config)
>>+ except Exception, ex:
>>+ # Call failed.
>>+ # See if we have a fault handling vector installed in our
>>+ # config. If we do, invoke it. If it returns a
>>true value,
>>+ # retry the call.
>>+ # In any circumstance other than the fault
>>handler returning
>>+ # true, reraise the exception. This keeps the
>>semantics of this
>>+ # code the same as without the fault_handler code.
>>+ if hasattr(self.config, "fault_handler"):
>>+ if callable(self.config.fault_handler):
>>+ call_retry =
>>self.config.fault_handler(self.proxy, ex)
>>+ if not call_retry:
>>+ raise
>>+ else:
>>+ raise
>>+ else:
>>+ raise
>>+ if call_retry:
>>+ encoding
>>= self.encoding,
>>+ http_proxy =
>>self.http_proxy,
>>+ config =
>>+ self.config)
>>+ print r
>> p, attrs = parseSOAPRPC(r, attrs = 1)
>> try:
>>With this mod to hosting/SOAPpy/Client.py:
>>diff -u -r1.6 Client.py
>>--- Client.py 2 Mar 2004 19:12:47 -0000 1.6
>>+++ Client.py 8 Mar 2004 20:51:20 -0000
>>@@ -29,7 +29,7 @@
>> A class that encapsulates a SOAP proxy.
>> def __init__(self, url, namespace = None, authCallback
>>= None, debug = 0,
>>- config = None):
>>+ config = None, faultHandler = None):
>> @param url: the url to the service
>> @param namespace: the namespace for the service @@
>>-46,6 +46,7 @@
>> self.config = config
>> self.config.debug = debug
>>+ self.config.fault_handler = faultHandler
>> self.url = url.replace("https", "httpg")
>> self.proxy = None
>> self.namespace = namespace
>>We can write:
>>def fh(proxy, ex):
>> print "Fault handler invoked! proxy=%s exception=%s" % (proxy, ex)
>> return 0
>>try:
>> self.profile.capabilities = Client.Handle( self.nodeServiceUri,
>> faultHandler = fh).
>> GetProxy().GetCapabilities()
>>A non-stub fault handler would do something like query the
>>local cert mgmt infrastructure, which can interact with the
>>user, to create the right flavor of proxy if possible, and
>>return 1 to have the soap level retry the call.
>>Thoughts?
>>--bob
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20040308/368220fa/attachment.htm>
