Fault handling redirects in SOAPpy
Ivan R. Judson
judson at mcs.anl.gov
Mon Mar 8 15:51:05 CST 2004
Looks cool; but I'm missing the motivation for it? Is something broken
without this?
--Ivan
> -----Original Message-----
> From: owner-ag-dev at mcs.anl.gov
> [mailto:owner-ag-dev at mcs.anl.gov] On Behalf Of Robert Olson
> Sent: Monday, March 08, 2004 2:55 PM
> To: ag-dev at mcs.anl.gov
> Subject: Fault handling redirects in SOAPpy
> Try this on for size. In SOAPpy/CLient.py:
> --- Client.py~ 2004-02-17 22:05:59.000000000 -0600
> +++ Client.py 2004-03-08 14:45:21.000000000 -0600
> @@ -339,11 +339,46 @@
> header = hd, methodattrs = ma, encoding = self.encoding,
> config = self.config, noroot = self.noroot)
> - r, self.namespace = self.transport.call(self.proxy,
> m, ns, sa,
> - encoding =
> self.encoding,
> - http_proxy =
> self.http_proxy,
> - config = self.config)
> + call_retry = 0
> + try:
> + r, self.namespace =
> self.transport.call(self.proxy, m, ns, sa,
> + encoding
> = self.encoding,
> + http_proxy =
> self.http_proxy,
> + config =
> + self.config)
> + except Exception, ex:
> + # Call failed.
> + # See if we have a fault handling vector installed in our
> + # config. If we do, invoke it. If it returns a
> true value,
> + # retry the call.
> + # In any circumstance other than the fault
> handler returning
> + # true, reraise the exception. This keeps the
> semantics of this
> + # code the same as without the fault_handler code.
> + if hasattr(self.config, "fault_handler"):
> + if callable(self.config.fault_handler):
> + call_retry =
> self.config.fault_handler(self.proxy, ex)
> + if not call_retry:
> + raise
> + else:
> + raise
> + else:
> + raise
> + if call_retry:
> + encoding
> = self.encoding,
> + http_proxy =
> self.http_proxy,
> + config =
> + self.config)
> + print r
> p, attrs = parseSOAPRPC(r, attrs = 1)
> try:
> With this mod to hosting/SOAPpy/Client.py:
> diff -u -r1.6 Client.py
> --- Client.py 2 Mar 2004 19:12:47 -0000 1.6
> +++ Client.py 8 Mar 2004 20:51:20 -0000
> @@ -29,7 +29,7 @@
> A class that encapsulates a SOAP proxy.
> def __init__(self, url, namespace = None, authCallback
> = None, debug = 0,
> - config = None):
> + config = None, faultHandler = None):
> @param url: the url to the service
> @param namespace: the namespace for the service @@
> -46,6 +46,7 @@
> self.config = config
> self.config.debug = debug
> + self.config.fault_handler = faultHandler
> self.url = url.replace("https", "httpg")
> self.proxy = None
> self.namespace = namespace
> We can write:
> def fh(proxy, ex):
> print "Fault handler invoked! proxy=%s exception=%s" % (proxy, ex)
> return 0
> try:
> self.profile.capabilities = Client.Handle( self.nodeServiceUri,
> faultHandler = fh).
> GetProxy().GetCapabilities()
> A non-stub fault handler would do something like query the
> local cert mgmt infrastructure, which can interact with the
> user, to create the right flavor of proxy if possible, and
> return 1 to have the soap level retry the call.
> Thoughts?
> --bob
