Fault handling redirects in SOAPpy
    Robert Olson
    olson at mcs.anl.gov
    Mon Mar  8 14:54:38 CST 2004
Try this on for size. In SOAPpy/CLient.py:
--- Client.py~  2004-02-17 22:05:59.000000000 -0600
+++ Client.py   2004-03-08 14:45:21.000000000 -0600
@@ -339,11 +339,46 @@
              header = hd, methodattrs = ma, encoding = self.encoding,
              config = self.config, noroot = self.noroot)
-        r, self.namespace = self.transport.call(self.proxy, m, ns, sa,
-                                                encoding = self.encoding,
-                                                http_proxy = self.http_proxy,
-                                                config = self.config)
+        call_retry = 0
+        try:
+            r, self.namespace = self.transport.call(self.proxy, m, ns, sa,
+                                                    encoding = self.encoding,
+                                                    http_proxy =
self.http_proxy,
+                                                    config = self.config)
+        except Exception, ex:
+            # Call failed.
+            # See if we have a fault handling vector installed in our
+            # config. If we do, invoke it. If it returns a true value,
+            # retry the call.
+            # In any circumstance other than the fault handler returning
+            # true, reraise the exception. This keeps the semantics of this
+            # code the same as without the fault_handler code.
+            if hasattr(self.config, "fault_handler"):
+                if callable(self.config.fault_handler):
+                    call_retry = self.config.fault_handler(self.proxy, ex)
+                    if not call_retry:
+                        raise
+                else:
+                    raise
+            else:
+                raise
+        if call_retry:
+                                                    http_proxy =
self.http_proxy,
+        print r
          p, attrs = parseSOAPRPC(r, attrs = 1)
          try:
With this mod to hosting/SOAPpy/Client.py:
diff -u -r1.6 Client.py
--- Client.py   2 Mar 2004 19:12:47 -0000       1.6
+++ Client.py   8 Mar 2004 20:51:20 -0000
@@ -29,7 +29,7 @@
      A class that encapsulates a SOAP proxy.
      def __init__(self, url, namespace = None, authCallback = None, debug = 0,
-                 config = None):
+                 config = None, faultHandler = None):
          @param url: the url to the service
          @param namespace: the namespace for the service
@@ -46,6 +46,7 @@
              self.config = config
          self.config.debug = debug
+        self.config.fault_handler = faultHandler
          self.url = url.replace("https", "httpg")
          self.proxy = None
          self.namespace = namespace
We can write:
def fh(proxy, ex):
    print "Fault handler invoked! proxy=%s exception=%s" % (proxy, ex)
    return 0
try:
   self.profile.capabilities = Client.Handle( self.nodeServiceUri,
                                   faultHandler = fh).
					GetProxy().GetCapabilities()
A non-stub fault handler would do something like query the local cert mgmt
infrastructure, which can interact with the user, to create the right
flavor of proxy if possible, and return 1 to have the soap level retry the
call.
Thoughts?
--bob
