FW: [ace-research] Reminder: development meeting with Argonne folks, 4pm ET today
Ivan R. Judson
judson at mcs.anl.gov
Fri Jun 25 14:05:16 CDT 2004
-----Original Message-----
From: Khalil El-Khatib [mailto:khalil.el-khatib at nrc.gc.ca]
Sent: Friday, June 25, 2004 1:45 PM
To: ace-research at yahoogroups.com; Ivan R. Judson
Subject: Re: [ace-research] Reminder: development meeting with Argonne
folks, 4pm ET today
Hi folks,
Here is the paper I was talking about the other day. it talks about
distributed content adaptation, profiles,..I have submitted it couple of
weeks ago to QShine; cheers, khalil
----- Original Message -----
To: Ivan R. Judson <mailto:judson at mcs.anl.gov>
Cc: ace-research at yahoogroups.com
Sent: Wednesday, June 23, 2004 12:03 PM
Hi Ivan,
Andrew has given a high level overview of some of the topics we
would
like to discuss (see his email below). It starts with a description
of
our vision of how venues may work in the future. You may recognize
this
as similar to the discussion we had at the pub during the developers
sig.
To make this fairly concrete, I will try to paint a scenario for
this.
Our ACE service isn't truly a service or shared app per se. It is
really
a tool for creating a meeting session (a venue) with the right tools
available for the task being undertaken. The goal is to do this with
the
user having little technical knowledge or input to the process.
We want to integrate that into AG 2 so that it populates a venue
with
the appropriate set of services that are required to accomplish a
specific task. I think ideally it would be integrated into the venue
client proper, but for proof of concept we are looking at other
mechanisms. Here is the scenario.
A user wants to create a meeting. He/she runs the ACE service. They
are
asked a set of simple, non-technical questions. This identifies the
type
of task they are trying to perform, including the services required
to
accomplish the task and the parameter settings for each service
(quality
of video, audio, and other shared app parameters). After completion,
the
ACE service creates a venue on the server and populates it with the
required shared apps. It also populates the venue with parameter
settings for each shared app that the shared app uses on startup.
Thus
the "services" that start are tied to the venue, including the
quality
level settings.
When a user enters the venue the services that are in the venue
start
up, each of them using the parameter settings that are stored in the
venue. Thus the services are all configured as appropriate for the
meeting taking place, not based on the capability of the local node.
Our next prototype will probably have an ACE shared app that would
do
all of this configuring and use shared apps as the services (that is
we
would not use node services at all).
Some of the issues:
1) How do we create a venue on a server?
2) How do we add a shared app to a venue through the AGTK APIs?
3) What is the best way to store config information for a shared app
in
a venue?
4) We need shared apps to start on venue entry. This was mentioned
by
others at the AG retreat.
5) We need shared apps to read the config stuff on startup.
Initially we
can do this as part of the shared app, but this would be a nice
feature
in general for the future.
6) Shared apps don't know anything about nodes. Thus if we have a
video
service as a shared app there is no way to get it to run on another
machine in a node. In this instance we would want to have a shared
app
that provides a video/producer type of service check the node config
and
start up all of the video/producers in the node. Thus we would like
the
shared apps to negotiate with the node to determine how to deliver a
specific service on a specific node.
We talked about many of these things in Toronto, so I think this is
primarily a continuation of that discussion from our perspective.
What we want to get your help with is how best to build our next
prototype. We think the shared app approach is probable the easiest
one
to take at this point... In return, we will fill your heads with our
ideas and hope that some of them will be useful 8-)
Cheers,
Brian
Andrew Patrick wrote:
> Just a reminder that we are meeting with Ivan Judson and some
other
> Argonne folks this afternoon (1:00 PDT, 3:00 CDT, 4:00 EDT). We
will be
> meeting in the ACE room of the Westgrid Venue Server.
> Topics to be discussed:
> - describing our vision of the ACE service
> - each meeting space is customized for the task at hand, and the
> capabilities of the nodes at the time of the session
> - first prototypes built with Web interfaces ala AG 1
> - would like to build the next interface inside AG 2
> - what is the correct model for implementing within AG 2?
> - we tried building a node service, but got into problems?
> - building a shared application seems to work, but it would have
to
> restart the audio and video node services?
> - aren't audio and video really just shared applications, so
they
> should be treated like the others?
> Brian, can you build on this outline for the discussion?
Yahoo! Groups Sponsor
ADVERTISEMENT
click here
<http://us.ard.yahoo.com/SIG=129clff8h/M=298184.5022502.6152625.3001176/D=gr
oups/S=1705005512:HM/EXP=1088093100/A=2197946/R=0/SIG=11elgumq7/*http://www.
netflix.com/Default?mqso=60183367>
<http://us.adserver.yahoo.com/l?M=298184.5022502.6152625.3001176/D=groups/S=
:HM/A=2197946/rand=580162381>
Yahoo! Groups Links
* To visit your group on the web, go to:
http://groups.yahoo.com/group/ace-research/
* To unsubscribe from this group, send an email to:
ace-research-unsubscribe at yahoogroups.com
<mailto:ace-research-unsubscribe at yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20040625/5b4fc579/attachment.pdf>
