venueserver test script
Eric Olson
eolson at mcs.anl.gov
Fri Jun 25 09:16:31 CDT 2004
Per Ivan's request, here's a (Tom's) test script that enters and exits the
venueserver with multiple clients. Note: it needs to be updated to use
2.2.
import os
from AccessGrid.VenueClient import VenueClient
def PrintList( listname, thelist ):
print " ",listname," ------"
for item in thelist:
print " ", item.name
if "uri" in item.__dict__.keys(): print " uri = ", item.uri
class MyVenueClient( VenueClient ):
MyVenueClient is a wrapper for the base VenueClient.
It prints the venue state when it enters a venue or
receives a coherence event. A real client would probably
update its UI instead of printing the venue state as text.
def EnterVenue(self, URL):
Note: Overloaded from VenueClient
This method calls the venue client method and then
performs its own operations when the client enters a venue.
VenueClient.EnterVenue( self, URL )
#self.PrintVenueState()
def ExitVenue(self ):
performs its own operations when the client exits a venue.
VenueClient.ExitVenue( self )
#print "Exited venue ! "
def PrintVenueState( self ):
venueState = self.venueState
print "--- Venue State ---"
print " Name: ", venueState.name
print " Description: ", venueState.description
map( lambda listtuple: PrintList( listtuple[0], listtuple[1] ),
("Users", venueState.clients.values()),
("Connections", venueState.connections.values()),
("Data", venueState.data.values()),
("Services", venueState.services.values())
def Enter( venueUri, profile ):
print "Entering venue: name = ", profile.name
vc = MyVenueClient( profile )
vc.EnterVenue( venueUri )
if __name__ == "__main__":
import sys
from AccessGrid.hosting.pyGlobus.Server import Server
from AccessGrid.hosting.pyGlobus import Client
from AccessGrid.ClientProfile import ClientProfile
from AccessGrid.Types import *
NUM_VENUE_CLIENTS = 1
NUM_ROUNDTRIPS = 260
# process arguments
venueServerUri = "https://localhost:8000/VenueServer"
if len(sys.argv) > 1:
venueServerUri = sys.argv[1]
# Get default venue from venue server
print "Getting default venue"
venueUri = Client.Handle( venueServerUri ).get_proxy().GetDefaultVenue()
print "Reading profile"
vcList = []
print "Creating venue clients"
for id in range(NUM_VENUE_CLIENTS):
profile = ClientProfile('userProfile')
profile.name = "User"+str(id)
profile.publicId = profile.publicId + str(id)
vcList.append( MyVenueClient( profile ) )
for i in range(NUM_ROUNDTRIPS):
print "Roundtrip: ", i
print "Clients entering: "
for vc in vcList:
print " ", vc.profile.name
try:
except:
print sys.exc_type
print sys.exc_value
print sys.exc_info()
print "Clients exiting: "
for vc in vcList:
try:
vc.ExitVenue()
except:
print sys.exc_type
print sys.exc_value
os._exit(1)
# Create VenueClient and enter venue
#os._exit(1)
#profile.name = "Changed name"
#Client.Handle( venueUri ).get_proxy().UpdateClientProfile( profile )
# Create web service for venue client
server = Server( 8700 )
service = server.create_service_object("VenueClient")
vc._bind_to_service( service )
# Update venue client with venue client uri
vc.profile.venueClientUri = vc.get_handle()
#vc.coherenceClient.stop()
# Start service
print "Starting service; URI: ", vc.get_handle()
server.run()
