Gentoo Install
Thomas D. Uram
turam at mcs.anl.gov
Mon Jun 7 02:03:07 CDT 2004
The node services come out of the build process incomplete atm. You
should include the node service packages found in this zip file for now:
http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/2.2/updates/AGTk22_ServiceUpdate.zip
What source are you using for the build? In cvs and in the source
targz, GetBaseDir returns /etc/AccessGrid.
Ti Leggett wrote:
> I have the beginnings of the gentoo install done. I have all the prereqs
> done and most of the AGTk. What I'm missing are the node services. One
> thing I've noticed is that for some reason it tries to find the
> SharedApplications, NodeServices, and Services directories under /usr
> instead of /etc/AccessGrid/Config. I edited Platform/unix/Config.py to
> get the base dir from GetConfigDir instead of GetBaseDir and that seemed
> to fix it when the directories already existed. If they failed to make
> them and failed to start then. Not sure if this was the right thing or
> not.
