AccessGridNode on Linux
Thomas D. Uram
turam at mcs.anl.gov
Wed Jan 21 14:31:54 CST 2004
Matthias:
I'm glad to see someone working to get the AG on Suse, and am willing to
help out however I can.
The RunTime error about sslutilsc is related to pyGlobus (and possibly
openssl). The traceback may indicate a problem with pyOpenSSL. Both of
these are Python extension modules. I'm not sure whether you took
pyGlobus and pyOpenSSL from our cvs; if not, you should (using the tag
'release_2_1_2'), and build them on your system. This will resolve the
api version mismatch, and possibly the certificate request problem.
Let me know how things go after you've built pyGlobus and pyOpenSSL. If
you have any questions, let me know.
Tschuess,
Tom
>>-----Original Message-----
>>From: owner-agdev-ca at mcs.anl.gov [mailto:owner-agdev-ca at mcs.anl.gov]
>>Sent: Wednesday, January 21, 2004 5:19 AM
>>To: owner-agdev-ca at mcs.anl.gov
>>Subject: BOUNCE agdev-ca at mcs.anl.gov: Non-member submission
>>from [mmilczyn at TechFak.Uni-Bielefeld.DE]
>>From owner-agdev-ca at mcs.anl.gov Wed Jan 21 05:18:47 2004
>>Received: from mailout.TechFak.Uni-Bielefeld.DE
>>(mailout.TechFak.Uni-Bielefeld.DE [129.70.136.245])
>> by mcs.anl.gov (8.11.6/8.9.3) with ESMTP id i0LBIk9125442
>> for <agdev-ca at mcs.anl.gov>; Wed, 21 Jan 2004 05:18:47 -0600
>>Received: from mime.TechFak.Uni-Bielefeld.DE
>>(mime.TechFak.Uni-Bielefeld.DE [129.70.128.67])
>> by momotombo.TechFak.Uni-Bielefeld. DE
>>(8.11.7p1+Sun/8.11.6/TechFak/2003/04/16/pk) with ESMTP id i0LBIjv21886
>> for <agdev-ca at mcs.anl.gov>; Wed, 21 Jan 2004 12:18:45
>>+0100 (MET)
>>Date: Wed, 21 Jan 2004 12:18:45 +0100
>>From: mmilczyn at TechFak.Uni-Bielefeld.DE
>>To: agdev-ca at mcs.anl.gov
>>Subject: AccessGridNode on Linux
>>Message-ID: <710000.1074683925 at mime.TechFak.Uni-Bielefeld.DE>
>>X-Mailer: Mulberry/3.0.3 (SunOS/SPARC)
>>MIME-Version: 1.0
>>Content-Type: text/plain; charset=us-ascii; format=flowed
>>Content-Transfer-Encoding: 7bit
>>Content-Disposition: inline
>>X-Spam-Status: No, hits=1.0 required=5.0
>> tests=NO_REAL_NAME
>> version=2.55
>>X-Spam-Level: *
>>X-Spam-Checker-Version: SpamAssassin 2.55 (1.174.2.19-2003-05-19-exp)
>>Hello my name is Matthias Milczynski. I'm student of the
>>University Bielefeld (Germany). I tried to install the
>>AccessGrid-Toolkit2.1.2 which I took from CVS. My OS is Linux
>>Suse-Distribution 9.0. After installing required Software
>>like pyGlobus, pyOpenSSL, etc. I successfully started the
>>VenueClient.py module. During Certification (Request
>>Certification Step 3 of 3) I get an AttributeError:
>> Traceback (most recent call last):
>> File
>>"/amnt/loge/volumes/ni03/ilab/src/AccessGrid/AccessGrid/Certif
>>icateManagerW
>>XGUI.py", line 461, in CreateCertificateRequestCB
>> certificateRequest = repo.CreateCertificateRequest(name, password)
>> File
>>icateReposito
>>ry.py", line 592, in CreateCertificateRequest
>> sub.add(k, v)
>>AttributeError: No such attribute
>>01/21/2004 12:04:20 PM DEBUG ChangingPage:Values are not
>>correct, do not change page ###################### I don't
>>use the proxy sever.
>>How can I solve the problem? At the beginning of the
>>Certification I get a
>>warning:
>> RuntimeWarning: Python C API version mismatch for module
>>sslutilsc: This Python has API version 1012, module sslutilsc
>>has version 1010.
>>Maybe the error occurs because of the different versions?
>>It would be great if you could help me.
>>Thanks a lot!!
>>Matthias Milczynski
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20040121/f726f7c7/attachment.htm>
