FW: New experimental audio driver for the ALSA 1.0 API
Ivan R. Judson
judson at mcs.anl.gov
Wed Jan 14 18:28:06 CST 2004
This could fix a whole slew of problems if it's working.
--Ivan
> -----Original Message-----
> From: owner-rat-users at cs.ucl.ac.uk
> [mailto:owner-rat-users at cs.ucl.ac.uk] On Behalf Of Stefan Wenk
> Sent: Wednesday, January 07, 2004 1:12 PM
> To: Piers O'Hanlon
> Cc: rat-users; rat-trap; P.OHanlon
> Subject: Re: New experimental audio driver for the ALSA 1.0 API
> > Dear Stefan,
> > This looks great - we have been wanting to upgrade the ALSA
> support in
> > RAT
> for
> > sometime now. I haven't had a chance to test it yet but
> will get back
> > to
> you
> > when I have.
> Good to hear, please report your test results.
> >Do you know why the volume sliders do not work with your code?
> I looked at the API and also on the sources of qamix and gave
> up finally after having read
> http://www.mail-archive.com/alsa-devel@lists.sourceforge.net/m
> sg10142.html.
> > The original ALSA driver was produced by someone else and my
> > understanding
> was
> > that it supported ALSA v0.5x(?) - did you manage to update
> the driver
> > to
> 0.9x?
> Sorry for the confursion. Yes. The current auddev_alsa.c used
> in rat 4.2.24 is for ALSA API 0.5. I have mentioned this in a
> comment in auddev_alsa_old.c. The new driver is for the API
> version 0.9x or 1.0??. I though it was support for ALSA lib
> version 1.0 because this is the version you see in the
> generated doc directory of ALSA lib 1.0.0rc2. ALSA
> documentation is not as good and clear as it could be, see
> reference above, or I have messed something up, I don't know.
> > Let me know if you have any updates or fixes.
> I don't plan any new release. If you implement the mixer or
> find and fix bugs during your tests please go ahead. I'll
> perform testing on my hardware once you send your change
> directly to me (I'm not subscribed to rat-users or rat-trap
> because of all the spam).
> From what I have seen so far usage of an external mixer is
> needed in any case to get rat running properly under Linux,
> so the volum thing is not a very big limitation for an
> experimental driver. I hoped somebody more familiar with ALSA
> would do it.
> but
> probably only after a simplified mixer interface is available
> in stable form see
> (http://www.mail-archive.com/alsa-devel@lists.sourceforge.net/
> msg09429.html)
> Stefan
