For the brave...
Justin Binns
binns at mcs.anl.gov
Mon Aug 16 14:08:09 CDT 2004
Thanks for the great test!
This installer really only starts the Venue Client, so I'm not surprised
you couldn't 'manage my node' - I'll work on a more thorough startup
script. For now, if you want to run other services (they're all there),
you can change into the installed bundle (It'll be something like
'/Applications/Access Grid Toolkit.app') and look at the
'Content/MacOS/runag.sh' script. Basically, you set a couple
environment variables to point into the bundle (notably the
GLOBUS_LOCATION and PYTHONPATH variables) and then you can manually run
any of the scripts using pythonw. Also, there aren't any media tools
yet (just the core toolkit), though as soon as there are some working,
I'll be glad to add them ;-) I'm also glad it worked using 10.3.4 - I
wasn't sure it would. Thanks again!
Justin
On Mon, 2004-08-16 at 13:50, Paul Mercer wrote:
> Justin
> Here is what I did:
> I downloaded the AG install package and installed it on a mac laptop,
> tibook, running 10.3.4.
> Installer worked fine.
> Upon starting venue client I got a window that indicated there was no cert.
> I set up my profile when asked.
> Exported the cert from another node to a usb jump drive.
> After venue client stated I imported my cert from the usb jump drive
> using the Certificate Manager.
> The venue client shows all participants in the venue and I am able to
> navigate between venues.
> I set the Node URl to https://localhost:11000/NodeService.
> I'm not able to navigate to manage my node. From the preferences
> pull down menu, I select "manage my node", choose
> https://localhost:11000/NodeService and click OK.
> I then get Node Management Error window...Can not open node
> management at https://localhost:11000/NodeService.
> I upgraded to 10.3.5
> Restarted Venue Client
> I added a test doc to data and removed it.
> Are there audio and video services to add (vic and rat or others?)?
> I couldn't find them if they were installed.
> Finally I quit and restarted the Venue Client. Cert was still good,
> didn't have to reenter the cert passphrase and my profile was still
> intact.
> I have two students working on the video and audio along with Eric
> Olson and Ivan.
> If I can be of more help in getting ag ported to os x please ask.
> Paul
> At 6:23 PM -0500 8/13/04, Justin Binns wrote:
> >For anyone who wants to be brave, and who has a Mac, I'd appreciate folks
> >testing my AG install package. You can get it at the URL below. Warning,
> >it's 61MB. On the other hand, it includes *everything* you need,
> >including wxPython, globus, pyglobus, etc. It should work 'out of the
> >box' on just about any system, as long as you're running the latest
> >updated version of Panter (10.3.x). Let me know, both about successes and
> >failures. Thanks!
> >Justin
> >http://www-unix.mcs.anl.gov/~binns/AGTk-2.3beta.dmg.gz
