For the brave...
Paul Mercer
mercer at arsc.edu
Mon Aug 16 13:50:38 CDT 2004
Justin
Here is what I did:
I downloaded the AG install package and installed it on a mac laptop,
tibook, running 10.3.4.
Installer worked fine.
Upon starting venue client I got a window that indicated there was no cert.
I set up my profile when asked.
Exported the cert from another node to a usb jump drive.
After venue client stated I imported my cert from the usb jump drive
using the Certificate Manager.
The venue client shows all participants in the venue and I am able to
navigate between venues.
I set the Node URl to https://localhost:11000/NodeService.
I'm not able to navigate to manage my node. From the preferences
pull down menu, I select "manage my node", choose
https://localhost:11000/NodeService and click OK.
I then get Node Management Error window...Can not open node
management at https://localhost:11000/NodeService.
I upgraded to 10.3.5
Restarted Venue Client
I added a test doc to data and removed it.
Are there audio and video services to add (vic and rat or others?)?
I couldn't find them if they were installed.
Finally I quit and restarted the Venue Client. Cert was still good,
didn't have to reenter the cert passphrase and my profile was still
intact.
I have two students working on the video and audio along with Eric
Olson and Ivan.
If I can be of more help in getting ag ported to os x please ask.
Paul
At 6:23 PM -0500 8/13/04, Justin Binns wrote:
>For anyone who wants to be brave, and who has a Mac, I'd appreciate folks
>testing my AG install package. You can get it at the URL below. Warning,
>it's 61MB. On the other hand, it includes *everything* you need,
>including wxPython, globus, pyglobus, etc. It should work 'out of the
>box' on just about any system, as long as you're running the latest
>updated version of Panter (10.3.x). Let me know, both about successes and
>failures. Thanks!
>Justin
>http://www-unix.mcs.anl.gov/~binns/AGTk-2.3beta.dmg.gz
