Fwd: Re: [AG-TECH] Certificate import/export
Robert Olson
olson at mcs.anl.gov
Fri Sep 19 17:00:35 CDT 2003
if you have a chance can you talk to Victor about this then?
--bob
At 04:51 PM 9/19/2003 -0500, Eric Olson wrote:
>Happens to me if there are no streams in the venue -- of course this never
>happens to me in the TVS lobby since there are always streams there.
>Also, if the personalNode fails somehow or the nodesetupwizard was
>used to created a config file without a videoconsumer.
>Someone else mentioned an issue with a multi-machine node where the
>services did not always load correctly from their saved config file,
>and they had to manually start or add the services sometimes. The
>user was Monkia..., and Tom was there too, but I don't believe we found
>out what the problem was.
>Eric
>On Fri, 19 Sep 2003, Robert Olson wrote:
> > has anyone seen a problem where the vic receive window doesn't show up?
> > --bob
> > >From: "Victor M. Babson, Jr." <vbabson at secsg.uga.edu>
> > >To: "Robert Olson" <olson at mcs.anl.gov>
> > >Subject: Re: [AG-TECH] Certificate import/export
> > >Date: Fri, 19 Sep 2003 16:46:26 -0400
> > >X-Mailer: Microsoft Outlook Express 6.00.2800.1158
> > >X-Spam-Status: No, hits=0.8 required=5.0 tests=PORN_11 version=2.21
> > >X-Spam-Level:
> > >This is running on RH 7.3 fully patched.
> > >Correct. The vic window never comes up.
> > >How can I ensure that the video feed is getting into AG?
> > >I've used the configure node thing, and it sees my webcam...
> > >Now when I try to connect it kicks me off saying my connection was
> > >interrupted...
> > >--Vic
> > >----- Original Message -----
> > >From: "Robert Olson" <olson at mcs.anl.gov>
> > >To: "Victor M. Babson, Jr." <vbabson at secsg.uga.edu>
> > >Sent: Friday, September 19, 2003 3:46 PM
> > > > At 03:39 PM 9/19/2003 -0400, Victor M. Babson, Jr. wrote:
> > > > >It returns ag.secsg.org. I'll look into setting the GLOBUS_HOSTNAME.
> > > > yes, please let me know what happens. It seems quite odd that it's
> picking
> > > > up localhost.localdomain. What OS version is this computer running?
> > > > >I've just finished setting AG up on an XP box. When I connect I
> hat the
> > > > >audio window pop up, but my waiting on video window never pops up.
> > > > Do you mean a vic window never comes up, or it comes up sayiing
> "waiting
> > > > for video" ?
> > > > > Looks
> > > > >like I'll have to configure something somewhere so it know video
> needs to
> > >be
> > > > >fed.
> > > > Yes, you have to do some configuration to generate video. There are
> some
> > > > notes on room-based nodes at
> > >http://www-unix.mcs.anl.gov/fl/research/accessgrid/documentation/index.
> html
> > > > that should help with getting video capture working.
> > > > >I was hoping we could get this going in a day as I am busy with a few
> > >other
> > > > >projects, but it looks like you have to be pretty involved with
> this to
> > >get
> > > > >things going...
> > > > Sigh, you seem to be running into more troubles than other folks. Sorry
> > > > about that.
> > > > --bob
