Fwd: Re: [AG-TECH] Certificate import/export
Eric Olson
eolson at mcs.anl.gov
Fri Sep 19 16:51:16 CDT 2003
Happens to me if there are no streams in the venue -- of course this never
happens to me in the TVS lobby since there are always streams there.
Also, if the personalNode fails somehow or the nodesetupwizard was
used to created a config file without a videoconsumer.
Someone else mentioned an issue with a multi-machine node where the
services did not always load correctly from their saved config file,
and they had to manually start or add the services sometimes. The
user was Monkia..., and Tom was there too, but I don't believe we found
out what the problem was.
Eric
On Fri, 19 Sep 2003, Robert Olson wrote:
> has anyone seen a problem where the vic receive window doesn't show up?
> --bob
> >From: "Victor M. Babson, Jr." <vbabson at secsg.uga.edu>
> >To: "Robert Olson" <olson at mcs.anl.gov>
> >Subject: Re: [AG-TECH] Certificate import/export
> >Date: Fri, 19 Sep 2003 16:46:26 -0400
> >X-Mailer: Microsoft Outlook Express 6.00.2800.1158
> >X-Spam-Status: No, hits=0.8 required=5.0 tests=PORN_11 version=2.21
> >X-Spam-Level:
> >This is running on RH 7.3 fully patched.
> >Correct. The vic window never comes up.
> >How can I ensure that the video feed is getting into AG?
> >I've used the configure node thing, and it sees my webcam...
> >Now when I try to connect it kicks me off saying my connection was
> >interrupted...
> >--Vic
> >----- Original Message -----
> >From: "Robert Olson" <olson at mcs.anl.gov>
> >To: "Victor M. Babson, Jr." <vbabson at secsg.uga.edu>
> >Sent: Friday, September 19, 2003 3:46 PM
> > > At 03:39 PM 9/19/2003 -0400, Victor M. Babson, Jr. wrote:
> > > >It returns ag.secsg.org. I'll look into setting the GLOBUS_HOSTNAME.
> > > yes, please let me know what happens. It seems quite odd that it's picking
> > > up localhost.localdomain. What OS version is this computer running?
> > > >I've just finished setting AG up on an XP box. When I connect I hat the
> > > >audio window pop up, but my waiting on video window never pops up.
> > > Do you mean a vic window never comes up, or it comes up sayiing "waiting
> > > for video" ?
> > > > Looks
> > > >like I'll have to configure something somewhere so it know video needs to
> >be
> > > >fed.
> > > Yes, you have to do some configuration to generate video. There are some
> > > notes on room-based nodes at
> >http://www-unix.mcs.anl.gov/fl/research/accessgrid/documentation/index.html
> > > that should help with getting video capture working.
> > > >I was hoping we could get this going in a day as I am busy with a few
> >other
> > > >projects, but it looks like you have to be pretty involved with this to
> >get
> > > >things going...
> > > Sigh, you seem to be running into more troubles than other folks. Sorry
> > > about that.
> > > --bob
