[wxPython-users] wxWizard (fwd)
Susanne Lefvert
lefvert at mcs.anl.gov
Fri Sep 19 15:13:02 CDT 2003
Ah, I probably didn't shut down the node stuff properly.
Susanne
On Fri, 19 Sep 2003, Susanne Lefvert wrote:
> I'm posting this to the list because I don't really know why this error
> occurs when I run the NodeSetupWizard. Any ideas?
> Susanne
> ---------- Forwarded message ----------
> Date: Fri, 19 Sep 2003 12:48:38 -0700
> From: Robin Dunn <robin at alldunn.com>
> Reply-To: wxPython-users at lists.wxwindows.org
> Subject: Re: [wxPython-users] wxWizard
> > Sometimes when I cancel my wizard I'm getting this error on linux. Does
> > anybody know what might cause it? This is how I run it:
> > pp = wxPySimpleApp()
> > n = MyWizard()
> > n.Destroy()
> > I suspect the Destroy() call is causing it, but if I leave that out,
> > running the wizard on windows will tell me that I still have open
> > windows (and the wxPython documentation says 'don't forget to call
> > Destroy on the wizard'). This is the exception that I sometimes get:
> > Unhandled exception in thread:
> > Traceback (most recent call last):
> > File "/usr/src/build/87651-i386/install/usr/lib/python2.2/threading.py",
> > line 424, in __bootstrap
> > line 433, in __delete
> > AttributeError: 'NoneType' object has no attribute 'acquire'
> Do you import and use threading? wxPython itself doesn't...
> What does MyWizard look like?
> Robin Dunn
> Software Craftsman
> http://wxPython.org Java give you jitters? Relax with wxPython!
> To unsubscribe, e-mail: wxPython-users-unsubscribe at lists.wxwindows.org
> For additional commands, e-mail: wxPython-users-help at lists.wxwindows.org
