[wxPython-users] wxWizard (fwd)
Susanne Lefvert
lefvert at mcs.anl.gov
Fri Sep 19 15:01:08 CDT 2003
I'm posting this to the list because I don't really know why this error
occurs when I run the NodeSetupWizard. Any ideas?
Susanne
---------- Forwarded message ----------
Date: Fri, 19 Sep 2003 12:48:38 -0700
Reply-To: wxPython-users at lists.wxwindows.org
Subject: Re: [wxPython-users] wxWizard
Susanne Lefvert wrote:
> Sometimes when I cancel my wizard I'm getting this error on linux. Does
> anybody know what might cause it? This is how I run it:
> pp = wxPySimpleApp()
> n = MyWizard()
> n.Destroy()
> I suspect the Destroy() call is causing it, but if I leave that out,
> running the wizard on windows will tell me that I still have open
> windows (and the wxPython documentation says 'don't forget to call
> Destroy on the wizard'). This is the exception that I sometimes get:
> Unhandled exception in thread:
> Traceback (most recent call last):
> File "/usr/src/build/87651-i386/install/usr/lib/python2.2/threading.py",
> line 424, in __bootstrap
> line 433, in __delete
> AttributeError: 'NoneType' object has no attribute 'acquire'
Do you import and use threading? wxPython itself doesn't...
What does MyWizard look like?
Robin Dunn
Software Craftsman
http://wxPython.org Java give you jitters? Relax with wxPython!
To unsubscribe, e-mail: wxPython-users-unsubscribe at lists.wxwindows.org
For additional commands, e-mail: wxPython-users-help at lists.wxwindows.org
