thread-pool for soap server
Robert Olson
olson at mcs.anl.gov
Tue Nov 11 22:30:17 CST 2003
as I discussed with tom today, here's an initial cut at a thread pool-based
soap server. Lightly tested, and doesn't have support for adding to the
pool if it gets hung up with blocked connections.
This is also against an unpatched aggsisoap module. All files go in the
hosting/pyGlobus dir.
The use of hte threadpool is triggered by adding the threadPoolSize arg to
the Server constructor:
server = Server.Server(8000, auth_callback = cb, threadPoolSize = 3)
--bob
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20031111/c76be423/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20031111/c76be423/attachment-0001.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20031111/c76be423/attachment-0002.obj>
